03-04-2004, 10:41 | #1 (permalink) |
Junior Member Join Date: Mar 2004 Age: 63
Member: 56734 Status: Offline Thanks Meter: 0 | 3210 screen fault I've got an old Nokia 3210 that has a fault: the screen is blank. It charges OK. Turn it on and the backlight comes on. Keys beep. Just no display. I'ev swapped the screen assembly and elastomer for new ones, hoping I could get a cheap spare phone for my kid. Do you guys know what might be the likely fault? I suspect a hardware problem on the PCB and a costly repair. Cheersthenyeah BigRich |
03-05-2004, 18:47 | #3 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | can be damaged CPU. Look in to a service manual and chceck lines from LCD. One of lines go to resistor near CPU. One time i had problem that this resistor was shorted and it was bad CPU |
8910i screen fault? | Hotdog | Nokia Hardware & Hardware Repair | 2 | 10-07-2004 15:49 |
GX10i weird main screen fault | rotorman | Sharp | 0 | 09-11-2004 10:56 |
V50 Screen Fault | yeldar | Motorola Old Legacy (EMMI) | 1 | 02-27-2003 12:41 |
3210 1800Mhz fault | Zoolee | Nokia Hardware & Hardware Repair | 5 | 02-22-2003 04:35 |
3210 Charging fault | Vicky | Nokia Hardware & Hardware Repair | 7 | 12-10-2001 00:49 |
