3220 *,0,# clr, key not work hi 3220 key *,0,# & clear not work there r z2400 emi filter ic sightly crack from corner there r conection of col4 need ic's input pin and output pin's diagram with this diagram i conect col4 input to output thnx |
cristal ic 1000000%%% |
there r must be replace EMI filter ic but without change ic how can i do co4 i/p to o/p conection posible???????????????? thnx |
3220 no wark 2.5.8.0 kiperd halp me |
check row colon continuty vertical,centre point ( or check continuty with ok pcb then compare ) horizental,outside circle point no need to change keypad ic...... B R Amit Tank |
cristal ic ?????? are you nut's |
