3220 droping signal this is a new phone.about to sold to user but when power on the phone.the signal bar will be at half of the full bar lenght.and after a while it will droping until one bar and it start going up to half bar lenght.i have reflow the hagar and wrote pm still no way. |
hi bro, try to change pa it will be solved best of luck jimmy |
3220 no signal i have a 3220 no signal. what the best way i do to repair it? thank you |
hi bro lanrian24 bro, if your network not show manually then change antina switch if your network comes and go then change pa send again best of luck jimmy |
Try to change antenna switch first and then PA if still |
hello bro;anybody help please;;;;; 6280 everithing is ok only incoming is not coming out going,network,all functions ok.idid master reaset also still not ok incoming.....please argent |
hello brothers;anybody help please;;;;; 6280 everithing is ok only incoming is not coming out going,network,all functions ok.idid master reaset also still not ok incoming.....please argent |
bro, write pm only then reflash.. |
1 Attachment(s) Quote:
Replace this [RED MARKED ] Set will be allright. post result |
hi, imran mz 1 is right. 100/. solved your problem....* 3 and yes and power button togather push them..set take format auto then your problem is solve.../.....thank......... |
write pm , reball uem.... |
