Old 12-03-2005, 16:02   #1 (permalink)
Member: 126927
3220 restart problem
3220 restart problem sim inside nokia logo and LCD APPEARED
twister flasher "erasing error 10:0x01000000-......... "
error mesage
pls help me
Old 12-03-2005, 17:14   #2 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
error mesage
pls help me
Hi,
For error 10 u try to reinstall DCTx of sarasoft and flash again!!!
I have 7260 restart problem with SIM or no SIM too. With SIM the phone seem be normaly but after 32 seconds it will restart. And it will be restart about 4 or 5 times then turn off. I have changed 26Mhz, UPP, Flash but no change. I will try to change UEM.
B.R
Old 12-06-2005, 13:37   #3 (permalink)
Member: 149576
Thanks Meter: 57
try Jaf flasher if u have one! they hav gud update now..
Old 12-06-2005, 14:49   #4 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
OK, Thanks
I think too but I don't have JAF box. Tomorow I will try to flash it by my friend's box.
B.R
Old 01-20-2006, 17:17   #5 (permalink)
Member: 220259
Sonork: 100.1584294
Thanks Meter: 28
error mesage
pls help me
use griffin to solve this problem. because im dam sure.i can face is around 7 times
Old 02-03-2006, 20:09   #6 (permalink)
Member: 62563
Sonork: 100.1589899
Thanks Meter: 26
hi there mate i have 7260 also complete flashing without sim card work good but sim inside when appear nokia logo rebooting!!!
Old 02-03-2006, 20:11   #7 (permalink)
Member: 62563
Sonork: 100.1589899
Thanks Meter: 26
pls help me about my problem!!!!!!!!!!!!!!!!!!!!!!!!
Old 02-03-2006, 21:03   #8 (permalink)
tirum's Avatar
Member: 100764
Thanks Meter: 4
error mesage
pls help me
hi
this is not flash ic or UEM ic or flashing problem
chang the CPU ic then u need to flash phone then u check
good luck
tirum
Old 02-03-2006, 23:52   #9 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Thanks Meter: 190
read information phone and see if IMEI is ????
Old 02-11-2006, 19:07   #10 (permalink)
Member: 194540
Thanks Meter: 7
3220 lcd ways pppplllllllllllllllllllllllsssssssssssssss
Old 02-11-2006, 19:20   #11 (permalink)
Member: 63754
Sonork: 100.1594531
Thanks Meter: 13
install griffinsofware for flash and phoenix update
and full erase with saras software after this process full flash mcu+ppm+cnt,
after updating phoenix support on many nokia model (3220,6020 &wd also)
i tried on many and successed 100%
Old 02-11-2006, 20:15   #12 (permalink)
Member: 63754
Sonork: 100.1594531
Thanks Meter: 13
3220 restart after flash after inserting sim card try to flash with this cnt file
3220cnt
6020cnt
Old 02-11-2006, 20:32   #13 (permalink)
yousaf22us's Avatar
Member: 113943
Thanks Meter: 73
bro use 128 cnt with same version which version of cnt i hope ur problem is solved if software problem in ur mobile if still same then rehot or replaced pa is weak wen ur set trying to collect signal its damin go offand dont forget full factory n ul default after flashing
Old 02-14-2006, 14:00   #14 (permalink)
Member: 113892
Thanks Meter: 57
sol restart
it's a cnt problem.... switch t cnt128 friend ... all will be ok !
Old 02-27-2006, 09:46   #15 (permalink)
Member: 194540
Thanks Meter: 7
3220
display light is not working pls help me
nokia 3220 auto restart problem Gautam Mhz Nokia Hardware & Hardware Repair 1 10-26-2009 09:59
nokia 3220 restart problem Shakeel_pattoki Nokia Hardware & Hardware Repair 0 03-11-2008 19:13
3220 Restarting problem skd_123 Nokia Hardware & Hardware Repair 13 08-12-2007 17:45
3220 restarts hdeshmeh Nokia Digital Core Technology 4 ( DCT-4 ) 3 04-21-2005 22:57
Page generated in 0.26371 seconds with 10 queries
