3220 restart when press 1 and call i have 3220..when i press 1 and call phone is restart.. what the problem is?:confused: plzzzzz help me...thanx |
try to reheat the ic beneath the 1 and call key |
try 1st flashing,, if the problem is still there,, reheat/replace the driver,, and lastly the upp!! |
change keypad ic ..........if not solve reball CPU |
bro, try to clean pcb as well first.......... |
try to flash it firstly and if not solved i think it will be CPU but believe me that will end by software |
means when we press on off switch it show switch off is it showing that post reply |
maybe its not a software problem.. coz i flash with ufs but still same.i will try reheat cpu.. thanx all....:):):) |
bro...the problem is when press number 1 n press call the phone will restart. i flash it before,but still same problem.:) |
br, try erase u phone then flash again and write good pm file....if not done try to rehot cpu..........boc it's a cpu problem. |
1-try to clean keypad pcb and metals that pressed in switches that has problum 2-clean all of board 3-heat keypad ESD chip 4-replace ESD chip 5-rehot cpu 6-reball cpu |
thanx all...the problem is solve. i reheat cpu..:D:D:D:D:D:D thanx for the solution. |
