07-17-2010, 11:33 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: kolkata
Member: 772386 Status: Offline Thanks Meter: 157 | 3220 strange problem Version Info: MCU SW version: V 06.22 23-05-07 RH-37 (c) Nokia. HW version: 5053 UEM version: 400 UPP version: 8514 RFIC version: 0205 DSP version: P05w06.v34_SLM LCD version: AMAZON PPM version: V 06.22 23-05-07 RH-37 (c) Nokia. W Product Info: Production serial number: MRB431288 Product code: 0518260 Module code: 0202178 Basic production code: 0519858 ATO: m????????????????????????????????????????????????? Serial Numbers: IMEI plain: 352737010472802 IMEI spare to net: 3A 25 37 07 01 74 82 IMEI SV to net: 33 25 37 07 01 74 82 20 F1 Other Info: Model : Nokia 3220 (Classic Phone) CS type : GSM900/GSM1800/GSM1900 Project Name: Asterix BSI: 3.5 KOhm Imei net: 35273701047280 Version: SIMLOCK SERVER VERSION 58 Provider: ALL Operator, Country: - Counter: 0/3, 0/10 CONFIG_DATA: 0010100000000000 PROFILE_BITS: 0000000000000002 BLOCK 1: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 2: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 3: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 4: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 5: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 6: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN BLOCK 7: 1.OPEN 2.OPEN 3.OPEN 4.OPEN 5.OPEN what i do its very urzent help me plz plz |
07-17-2010, 11:37 | #2 (permalink) |
No Life Poster Join Date: Apr 2009 Age: 41
Member: 1015389 Status: Offline Sonork: 19830303 Thanks Meter: 526 | did you try to full erase the phone then flash again and write pm and do full ui if still same you can check the flash ic reheat may help you to fix the phone.. good luck best regard.. |
07-17-2010, 11:39 | #3 (permalink) |
Member: 772386 Status: Offline Thanks Meter: 157 | phone self test info hone Type: RH-37 SW version: V 06.22 23-05-07 RH-37 (c) Nokia. ID Test name Startup Result 46 UEM_CBUS_IF Y passed 1 AUX_DA_LOOP Y passed 3 EAR_DATA_LOOP Y passed 17 TX_IDP_LOOP Y passed 18 TX_IQ_DP_LOOP Y passed 12 SIM_CLK_LOOP Y passed 13 SIM_IO_CTRL_LOOP Y passed 8 MBUS_RX_TX_LOOP Y passed 39 WARRANTY N passed 51 PA_TEMP Y passed 33 SIM_LOCK Y passed 10 PPM_VALIDITY N passed 7 KEYBOARD_STUCK N passed 41 FLASH_CHECKSUM N PASSED(00) 22 CAMERA_IF N !NOT EXECUTED(03) 54 EXT_RAM_DATA_BUS N !NOT EXECUTED(03) 55 EXT_RAM_ADDR_BUS N !NOT EXECUTED(03) help me plz plz |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
6110 5.47 sw unlock problem | gsms | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-21-1999 19:43 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
