07-15-2007, 04:29 | #1 (permalink) |
Freak Poster Join Date: Feb 2007 Location: cavite phils.
Member: 455665 Status: Offline Thanks Meter: 36 | 3230 camera fault |
07-15-2007, 06:54 | #2 (permalink) |
No Life Poster Join Date: Jan 2006 Location: EGYPT Age: 47
Member: 217479 Status: Offline Thanks Meter: 267 | At first the camera problem mostly it was hardware problem but now you have to solve the current problem: 1- Be sure that the IMEI still good & not went ??????????????? 2- Try to format the set manually. 3- Try to make full erase then to flash with latest version available, write a good PM file, apply full UI settings then format again. After finish get back your set software fixed: 1- Check the camera module & try another trusted one. 2- Check camera connector pins solder & cleanliness. 3- Check the shown connector in attached picture by cleaning & replace it if required also the opposite one on flex cable. |
07-15-2007, 06:59 | #3 (permalink) |
No Life Poster Join Date: Sep 2002 Location: KERALA, india Age: 55
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | @ mobilagy , exactly the correct procedure u said there may a chance of some print break on canera ways too cause this problem try and post result |
The Following User Says Thank You to neilthirumuttam For This Useful Post: |
07-15-2007, 07:26 | #5 (permalink) |
Member: 455665 Status: Offline Thanks Meter: 36 | thanks! contact retailer is ok. but the original problem is still there, i change the camera module because the original one is broken but it still ''feature not supported'' when cam is switched |
07-15-2007, 07:33 | #8 (permalink) |
Member: 15903 Status: Offline Sonork: 100.1583162 Thanks Meter: 1,046 | http:///vbb/showthread.php?t=420320 READ THIS |
01-22-2008, 10:01 | #13 (permalink) |
Freak Poster Join Date: Jun 2004 Location: mars Age: 45
Member: 69445 Status: Offline Thanks Meter: 12 | niceday...pls do help me...any one could post me a way to troobleshoot my n3230 "feature not supported" when camera starts,ive tryed to change the whole topboard and also the camera but still the same problem... thank you! |
E700 Camera fault (Preview Error). | fsmobile | Samsung Hardware Repair | 5 | 02-28-2005 16:33 |
7250 camera fault | JulesJ | Nokia Digital Core Technology 4 ( DCT-4 ) | 1 | 02-01-2005 15:47 |
V200 camera fault | blackharley-d | Trident/AGERE Platform | 2 | 10-01-2004 22:47 |
t610 camera fault | phone-tos | Sony Ericsson | 14 | 06-21-2004 09:16 |
Camera fault 7250 | The Dog | Nokia Hardware & Hardware Repair | 0 | 09-29-2003 12:37 |
