Old 12-23-2007, 19:28   #16 (permalink)
aduel's Avatar
Member: 60081
Thanks Meter: 9
it is in the mother bord cause i put it one working phone and it gave the same problem
Old 12-24-2007, 09:53   #17 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
REMOVE THE BOOT IC AND THEN CHECK AGAIN. .
Old 12-24-2007, 10:04   #18 (permalink)
Crazy Poster
Member: 184101
I think your mother board is ok now ,because it shows info na,
so first make confirm your lcd and upper board is ok.
then inform here again..........
Old 12-28-2007, 09:48   #19 (permalink)
Member: 447572
Thanks Meter: 5
Always 4mat d fone after flashing NEVER make Full fact.Settings 4 it will become Contact R. then u have to 4mat it again.If u can read info it means d mainBoard is working,Check d board connectors for loose contact.Better try another Top board to confirm source of problem.
Old 12-28-2007, 21:10   #20 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
hello,
you saying
if u check raning another set to check rady then only its a sofwear prob so read nicely .......when mcu and ppm flashing compelete then must be showing nokia logo if show nokia logo then ui if not change flash file or wait for showing logo in that case i do my self seclect another ppm file and select only ppm flash must be show nokia logo then i do ui ..........good luck
Nokia 3230 Problem With Midi supertraz Nokia Digital Core Technology 4 ( DCT-4 ) 0 02-04-2006 00:58
3230 problem in camera Triminity UFS2 + UFS3-Tornadoflasher 10 11-21-2005 11:34
3230 problem gsm st WD2 & APE (Symbian Phones) 4 10-22-2005 08:34
nokia 3230 problem?pls help faizalg WD2 & APE (Symbian Phones) 3 10-12-2005 13:39
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20059 seconds with 8 queries
