Old 08-18-2007, 06:33   #1 (permalink)
Member: 290360
Thanks Meter: 13
3230 white screen solution
3230 white screen. fone was water dam.now rest fone is workin but lcd is white.what to do????????
The Following User Says Thank You to broken_arrow For This Useful Post:
Old 08-18-2007, 14:43   #2 (permalink)
MSCOMMUNICATION's Avatar
Member: 190947
Sonork: 100.96272
Thanks Meter: 161
chang the disply ic if no work than chang strip if no than chang the front bord panal
MS COMMUNICATION
MOBILE PARTS&SOFTWERE
SHOP#87 &94 1ST FLOOR SARHAD PLAZA RAWALPINDI PAKISTAN
OFFICE 0515558766
MOBILE 03009786768
EMAIL [email protected]
[email protected] [email protected]
Old 08-18-2007, 19:15   #3 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
1.check with another display
2.check connecters for rust.display, uiboard and main board if u find any fault change connecters.
2.change ui board for checking.
3.last display ic's
Old 08-18-2007, 20:58   #4 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Arrow
check front UI & lcd first......replace lcd ic & first board conn if no help......post result
regards
PUNEET14884
Old 08-18-2007, 22:36   #5 (permalink)
Member: 275451
Thanks Meter: 84
chk display connector & board connector then chk for ui...then lcd..then lcd ic..
Old 04-07-2009, 12:12   #6 (permalink)
juliusorbiso's Avatar
Member: 884522
Sonork: 05261983
Thanks Meter: 87
i have nokia 3230 which has no display problem.it appears a white screen display always..
pls. help. i already change 2 lcd ic's and the lacd.
3230 white screen gsmshare98 Nokia Hardware & Hardware Repair 11 07-30-2007 14:38
3230 White Screen Solutions????? imran_qasim WD2 & APE (Symbian Phones) 31 06-04-2007 13:18
3230 White Screen & Can't Power On ccw123 MT-BOX 6 09-02-2006 00:34
3230 white screen and Blinking lcd skd_123 Nokia Hardware & Hardware Repair 3 07-15-2006 15:46
Page generated in 0.21343 seconds with 9 queries
