3250 charging problem hai nokia 3250 has a charging problem when i connect the charger to the phone it shows chargine but the problem is voltage to the battery connector output is 1.02v it should be 3.7v any alternative way pls replay soon thx in advanse :confused: :confused: :confused: :confused: :confused: :confused: |
i have same problem with my 3250 please send reply |
almost need to replace tahvo ic ........... |
hai nokia 3250 has a charging problemwhen i connect the charger to the phone it shows chargine but the problem is voltage to the battery connector output is 1.02v it should be 3.7v any alternative way pls replay soon thx in advanse plz.,,,,,. |
JUST CHANGE THE TAHVO UR PROBLEM WILL BE SOLVE. |
CHANE TAHVO........... |
Change TAHVO GOOD LUCK |
Change TAHVOooooooooooooo |
thx in adv |
DUDE IT IS FINAL SOLUTION WITHOUT WAISTING MUCH MORE PRECIOUS TIME .IT IS EASY TO DO.WHY R U HASITATE FROM THIS.JUST CONCENTRATE AND BE CONFIDENT.U CAN DO ANYTHING IF U HAVE CONFIDENCE ON URSELF.BEST OF LUCK |
see dear all BB5 the charging out should be 1 or 1.2 try to change and test more than one battery and charger |
3250 when i charge phone it will restarts and then chargi Quote:
what reallly is your problem? (1)unit restart then charge or (2)unit charging but not stored in battery? for problem number 1,,change retu problem number 2,,change tahvo,,,,,,,,,,,,,good luck;) |
chek battry it can br falty |
tahvo ic problem 100%... |
