Old 08-08-2006, 14:27   #1 (permalink)
Member: 70916
Thanks Meter: 55
3250 charging problem
hai nokia 3250 has a charging problem
when i connect the charger to the phone it shows chargine
but the problem is voltage to the battery connector output is 1.02v
it should be 3.7v any alternative way pls replay soon thx in advanse
The Following User Says Thank You to jbbasha For This Useful Post:
Old 11-28-2007, 17:38   #2 (permalink)
DIN231080's Avatar
Member: 523792
Thanks Meter: 96
i have same problem with my 3250 please send reply
The Following User Says Thank You to DIN231080 For This Useful Post:
Old 11-28-2007, 19:10   #3 (permalink)
Member: 45635
Thanks Meter: 20
almost need to replace tahvo ic ...........
The Following User Says Thank You to MAJESTIC PIRATE For This Useful Post:
Old 12-22-2007, 10:09   #4 (permalink)
Member: 293877
Sonork: 100.1612288
Thanks Meter: 23
hai nokia 3250 has a charging problemwhen i connect the charger to the phone it shows chargine but the problem is voltage to the battery connector output is 1.02v it should be 3.7v any alternative way pls replay soon thx in advanse plz.,,,,,.
The Following User Says Thank You to swagatam For This Useful Post:
Old 12-22-2007, 11:20   #5 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
JUST CHANGE THE TAHVO UR PROBLEM WILL BE SOLVE.
The Following User Says Thank You to xtremeburaq For This Useful Post:
Old 12-22-2007, 14:19   #6 (permalink)
Member: 553555
Thanks Meter: 6
CHANE TAHVO...........
The Following User Says Thank You to seeyou For This Useful Post:
Old 12-22-2007, 14:23   #7 (permalink)
Member: 553555
Thanks Meter: 6
Change TAHVO
GOOD LUCK
Old 12-22-2007, 14:27   #8 (permalink)
Member: 218793
Thanks Meter: 29
Change TAHVOooooooooooooo
The Following User Says Thank You to syedqurat For This Useful Post:
Old 12-22-2007, 15:52   #9 (permalink)
Member: 70916
Thanks Meter: 55
is there any alternative way with out changing tahvooooo ic
thx in adv
Old 12-22-2007, 15:59   #10 (permalink)
Registered User
Member: 483748
Thanks Meter: 47
DUDE IT IS FINAL SOLUTION WITHOUT WAISTING MUCH MORE PRECIOUS TIME .IT IS EASY TO DO.WHY R U HASITATE FROM THIS.JUST CONCENTRATE AND BE CONFIDENT.U CAN DO ANYTHING IF U HAVE CONFIDENCE ON URSELF.BEST OF LUCK
Old 12-23-2007, 01:57   #11 (permalink)
Member: 473823
Thanks Meter: 10
see dear all BB5 the charging out should be 1 or 1.2 try to change and test more than one battery and charger
The Following User Says Thank You to errant0 For This Useful Post:
Old 11-17-2008, 19:49   #12 (permalink)
Member: 408888
Thanks Meter: 25
Post 3250 when i charge phone it will restarts and then chargi
sir plz help me sirrrrrrrrrrrrrrrrrrrrrrrr
The Following User Says Thank You to suresh kumar For This Useful Post:
Old 11-17-2008, 20:00   #13 (permalink)
Member: 856796
Thanks Meter: 40
what reallly is your problem? (1)unit restart then charge or
(2)unit charging but not stored in battery?
for problem number 1,,change retu
problem number 2,,change tahvo,,,,,,,,,,,,,good luck
The Following 2 Users Say Thank You to bearhug For This Useful Post:
Old 11-17-2008, 20:26   #14 (permalink)
Member: 631464
Thanks Meter: 6
chek battry it can br falty
The Following User Says Thank You to tarun aggarwal For This Useful Post:
Old 11-01-2010, 12:47   #15 (permalink)
Member: 162055
Thanks Meter: 17
tahvo ic problem 100%...
3250 charging ROHINI Nokia Hardware & Hardware Repair 1 02-10-2009 12:08
3250 not charging problem shankarbrd Nokia Hardware & Hardware Repair 11 11-30-2008 18:34
3250 charging problem mo_gsm2013 Nokia Hardware & Hardware Repair 4 08-09-2008 09:30
Nokia 3250 charging problem mohiddin Nokia Hardware & Hardware Repair 3 05-05-2008 13:51
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.28646 seconds with 8 queries
