3250 freeze on nokia logo hi, initially this phone didn't recognize the sim card, it was staying always in offline mode.. i made a search in the forum and i made the ic ways.. but before that i had disassemble the phone off course, and after i soldered the wires on the ic, i assembled the phone. when i tryed to power on, it blinks on nokia logo and after a while it turns off.. after a while i saw that when i tryed to assemble the phone, i've mounted wrong the flex (reverse); and then i've assemble it in right way.. but the problem remains!!! what could happened to this phone?!?!?! i made the 3+*+green+power on and formated the phone, but the problem remains.. i've flashed with hwk and appears the following logo: 1ST BOOT : C0,07 [Rm-38] [2.0.8.0] RAPx ID : 000000010000022600010006010C192101001101 EM 1 ID : 00000232 EM 2 ID : 00000352 RAPx PBID : 200001149FE65056380B3696A11CA9E5B90BBF8A RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 191EC665DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 1.30.0 CMT FLID0 : 00EC22FE-00008921, Sam K8S5615ETA CMT FLID1 : 00EC22FE-00008921, Sam K8S5615ETA CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo_fps8.fg, Ver: 1.12.5 CMT KSIG0 : 779AAD630EC986E0CB64504357E9369F483BD4EE CMT VPP : Internal DUAL LINE : False CMT ALG Boot OK IMAGE : rm38_04.60_prod_core_APAC2.fpsx CMT NOR Erase Area: 0x00300000-01F3FFFF CMT NOR Erase Area: 0x0568F000-05ECFFFF CMT NOR Erase Area: 0x04800000-0480FFFF CMT NOR Erase Area: 0x00000000-002EFFFF CMT NOR Erase Area: 0x01F40000-01F7FFFF CMT NOR Erase Area: 0x01FA0000-01FDFFFF Process Failed, Repowering Mobile and i can't complete flash phone :( i'm really very desperate because i don't know what happened.. if someone could give an hand, i'll apreciate a lot :p many thanks in advance |
any ideas? :( i really don't have any.. |
Use 7 pins cable & use jaf.IF not done you must change flash file. |
i solved the problem... it should be because of any shunt on flex :) now it don't get any network, but i'll make some searches :) many thanks for the help |
Try To FUll Format The Phone And flash With Old Virson... Its Not Done Then Rehot CPU And UEM... |
