Old 07-17-2004, 19:05   #1 (permalink)
Member: 56665
Thanks Meter: 2
Question 9210i not detect mmc
hi guys,,,
9210i not detect mmc,what is problem?
help me please...
thanks.
Old 07-17-2004, 20:24   #2 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
try mmc with other 9210 phone,
if work ok you must check mmc connector.
if still, reformat ur 9210 by pres ctrl+Shift after battery inserted.
but you will lost ur data.
Old 07-28-2004, 17:19   #3 (permalink)
Member: 35576
no need to format. first check the MMC is ok, then check the SIM reader cum MMC cover ( cover near Battery) of 9210I for a projection on the left side.this projection on the cover works as a switch connection on the board.u can see this near the screw come under sim slot.if this one is ok then go ahead with mmc connector and related repair.good luck
Old 08-13-2004, 08:02   #4 (permalink)
Member: 17907
Thanks Meter: 42
yes vu3sbf is correct.
if it not accepting any mmc. check switch connection on left side.(near sim slot)
press it with any pin.
Old 08-13-2004, 08:06   #5 (permalink)
Member: 17907
Thanks Meter: 42
if not accepting only this mmc.may be your mmc corrupted. you can recover it.
go to file manager
then select menu button
then go to memory card option.
here only format memory card is enabled.
format it.
enjoy
Old 08-13-2004, 17:26   #6 (permalink)
Member: 18057
Thanks Meter: 64
@vu3sbf
great job done dear . thanx for your help really thanx
akki
Old 08-16-2004, 00:07   #7 (permalink)
Max_B's Avatar
Member: 16856
Sonork: 1582037
Thanks Meter: 441
Originally Posted by V3rl4ndy
hi guys,,,
help me please...
thanks.
First try to tight the screws near sim and mmc sockets, not to strong !
Second try to see [here]
Max_B
Sl45 Mmc Not Detect miecom Siemens Hardware Repair Area 0 02-04-2007 23:05
S65 not detecting RS-MMC card Lupo S-Gold Based Phones 1 07-21-2006 12:56
¯`·.¸¸.-MMC not detected by PC-.¸¸.·´¯ SALNAI Hardware Repair by brands 3 07-25-2005 12:16
MMC not detected in 9210 TokeiLampin Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 06-19-2005 20:39
Mmc not detected coticj x1x to x45/x50 8 06-26-2004 05:14
Page generated in 0.19270 seconds with 9 queries
