01-26-2004, 03:42 | #1 (permalink) |
No Life Poster Join Date: Jan 2004 Location: faraway from heaven Age: 41
Member: 50456 Status: Offline Thanks Meter: 1 | 3310 |
01-26-2004, 03:54 | #2 (permalink) |
No Life Poster Join Date: Dec 2001 Location: United Arab Emirates, Dubai Age: 52
Member: 7751 Status: Offline Thanks Meter: 74 | @Kiriazy More info is needed Have you flashed the phone, was it the original fault ? have you checked the DSP with Eeprom Tools ? Regards |
01-26-2004, 04:11 | #4 (permalink) |
Member: 50456 Status: Offline Thanks Meter: 1 | yes i check the sw before & afte any progress so i am sure from the sw & i haven't change teh hagar i replaced it with a solution i am sure of it reply plz |
01-26-2004, 04:49 | #5 (permalink) |
Member: 7751 Status: Offline Thanks Meter: 74 | @kiriazy Well, then you'll have to go deeper, but you did not explain more exact what you've been doing to the phone. And you did not try to reflash, you say that you checked the software before ? What was the original fault on this phone ? I need more info than you have given, but you can try to follow this procedure and report back. Try to follow the service manual, and check the following values : 1 : VB 3.6 V at C227/228 2 : 32.768 KHz at C220 (in my exsperince it does not matter if theres some noise at the edges of the sqaure wave, as long the freq. is ok) 3 : PWRNX at R402 is 3.6 V and drops to 0V during Press of PWR swicth 4 : VBB 2.8 V at C209/211 5 : Vxo 2.8 V at C243 6 : Vcore 1.7 V at L200 at both pads 7 : SLEEPX 2.8 V at J308 8 : PURX 2.8 V at R308 after PWR press 9 : 13 MHz at C303 Do please check all above and report back if some values are not ok. Regards |
01-28-2004, 15:35 | #6 (permalink) |
Member: 50456 Status: Offline Thanks Meter: 1 | thank u a lot but i have a little problem i don't know how i can mesure the Mhz can u tell me a way that i can mesure cause i only have (avo meter ) my regards |
3310 DAED AND 3310 NO NETWORK | ezz2003 | Nokia Hardware & Hardware Repair | 9 | 06-16-2007 18:03 |
3310 locked and 3310 without italian language ! | dadleit | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 10-17-2002 11:23 |
3310 v4.02 -> 3310 v5.57 ? | celo | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-19-2002 02:39 |
3310 ver 5.47 and 3310 to 3315 | Ramiz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 30 | 05-16-2002 17:15 |
3310 Into 6210 Or 3310 Into 6210 | voxsam | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-14-2002 19:53 |
