06-03-2003, 14:29 | #1 (permalink) |
Freak Poster Join Date: Jul 2002 Location: Croatia Age: 49
Member: 14004 Status: Offline Thanks Meter: 6 | 3310 & 3330 - phone jamed :) It shows charging normally. I can write and read flash without errors. I can power it on, then it shows blac screen for a second, and after that screen goes white and pohne is jamed... There is no water damage at all. What can i do? |
06-06-2003, 09:41 | #4 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | If above does not help then MCU is damaged... But, before throw board to garbage check all supply voltages from CCONT according to service manual...And use oscilloscope to check if there is noise in supply voltages... Check PURX signal with oscilloscope ( 2.8V every 60 sec )... Check sleepclk 32768kHz square wave at C220... Check 26MHz from crystal and 13MHz from HAGAR if there is any abbreviations in period or amplitude... Check RFC buffer... And good luck.....It is one of the worse malfunctions on NOKIA phones... BR Vule |
06-07-2003, 07:44 | #5 (permalink) |
Member: 14004 Status: Offline Thanks Meter: 6 | MCU balls broken :( Lot's of bad things happens when i press MAD2 a little bit.... I don't do changing glued components yet, ant the customer said that he wont pay more than 15 euro, so phone is now a toy for a 3 year old kid Thanks all for help. |
06-07-2003, 08:55 | #6 (permalink) |
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Sometimes You don't need to change mad... Just reheat it thru board ( not directly ) and put a lots of flux on it.... It's worth of try... BR Vule |
I Have 3310 With 3330 Board How To Install 3330 Firmware | LVVINE | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 14 | 06-22-2004 21:14 |
3310 & 3330 | ciberkido | Phone Unlocking Codes & Maps | 0 | 12-15-2003 07:30 |
serbian for 3310 & 3330 needed | magnum | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 09-07-2002 23:16 |
nokia 3310 & 3330 | phoneshack | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-02-2002 02:04 |
3310 & 3330 "Auto Turn Off" Solution | speed | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-03-2001 15:46 |
