04-26-2002, 13:32 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: P A K I S T A N _____________ Age: 40
Member: 5932 Status: Offline Thanks Meter: 1,694 | 3310 5 sec. sginal than no signal When i power on at the starting about 5 second signals come and than no singals at all. Please any one have any solution for repairing this fault than please reply to this topic or email me this solution. Thanks and Regards, Wahab [email protected] |
04-26-2002, 19:14 | #4 (permalink) |
Member: 5932 Status: Offline Thanks Meter: 1,694 | I completly checked that it not a software problem.. It is hardware problem.. Waiting for reply, Thanks and Regards, Wahab |
04-27-2002, 00:46 | #5 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Your antenna switch is sure damged 0508A or 0503 try to change it. Please refer if your problem is this, when you start manual search of networks , phone found networks but when you select this show "no access" right? |
04-28-2002, 20:06 | #6 (permalink) |
Major Poster Join Date: Mar 2002 Location: from nowhere Age: 50
Member: 10239 Status: Offline Thanks Meter: 0 | Hi! I have the same problem with my N3310,when i turned it on,full bar or a bars of netwofk, after 3 to 4 seconds it drops and no more.Any specific component you can suggest to change? Idias plz... j_h_u_n [email protected] www.geocities.com/jterc2000 |
04-29-2002, 14:27 | #10 (permalink) |
Freak Poster Join Date: Nov 1999 Location: South East Asia
Member: 662 Status: Offline Thanks Meter: 0 | I also have same problem.... Some of new 3310 v5.13 (made by nokia original PPM G) can only working with 1-2 operators while the other got no signal, some of them got full signal, 3-4 sec then drop.... Result when manual network selection is.. some of them can show all network that aviable, but "no access" when try to register... We already try to flash it with rolis, up to v5.13, also try use virgin eeprom, also try with full flash from healty phone, calculate with eeprom tools --> result the same... Also already try to flash with DDP and nokia wintelsa files, result the same.... Some of them we try to change the PA but still same.... any more idea? |
04-29-2002, 22:16 | #11 (permalink) |
Freak Poster Join Date: Aug 2001 Location: Baroda Age: 42
Member: 5871 Status: Offline Thanks Meter: 87 | Hello Everybody If your network fluctuation then change antenna swith..... If in mannual serching you got No Access then change pa.. If no network found then the may be problem of another thing my ICQ no is .... 118896550 bye from kulu |
3410 signal loose after 5 sec. | chrisro | Nokia Hardware & Hardware Repair | 23 | 09-04-2004 08:53 |
3310,power on full signal about 5 sec then no signal!!! | xchris | Nokia Hardware & Hardware Repair | 1 | 04-15-2002 05:52 |
No signal after 5 secs. | laxxe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 03-16-2002 20:49 |
3310 has signal but no signal strength indicator | brittnee | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-23-2001 02:01 |
