Old 04-17-2005, 17:26   #1 (permalink)
Member: 103968
Thanks Meter: 2
6100 Flash Ok but cannot turn on
Phone is dead
Flash OK ,Init simlock Ok , Full Factory Ok ,write pm Ok everything ok
but Cannot turn on Some time "Contact Service"
Old 04-17-2005, 18:18   #2 (permalink)
sevgigsm's Avatar
Member: 81576
Thanks Meter: 2,128
Originally Posted by NuengEve
Phone is dead
PM damaged
good PM to find
Old 04-17-2005, 19:07   #3 (permalink)
Member: 103968
Thanks Meter: 2
Now it's realy dead
but flash with tornado Ok connot turn on
Old 04-17-2005, 19:17   #4 (permalink)
Bypx's Avatar
Member: 62336
Thanks Meter: 115
Now it's realy dead
Hi, use erase file to erase phone flash and write mcu ppm cnt and good PM.
after do Full factory default & init sim locks.
Old 06-16-2005, 22:41   #5 (permalink)
Member: 72894
Thanks Meter: 23
never downgrade version from 3100/6100 phones, will cause dead. Try the latest version 6.01 Datapack 9.10.
Old 06-18-2005, 16:31   #6 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 135
probably Flash combo damage...
Old 06-18-2005, 16:59   #7 (permalink)
jarniel's Avatar
Member: 149600
Thanks Meter: 11
Now it's realy dead
after flashing did you see local mode on screen? if it has,check your switch.
Old 08-17-2005, 07:42   #8 (permalink)
LAD
Member: 51517
Thanks Meter: 24
i'v got the same problem, and still no difference after flashing with PBB (and les after flashing goes to test mode, NOT local mode):
when connected to flasher if tell it to goto normal mode, it goes but i get an error on the Phoenic prog saying:
"The mode refresh request failed.
The product is in the middle of a mode transition."
about the switch:
it does work as the phone switches on and off (but into contact service mode only)
i checked it's connections:
switch to ground ok - No resistance between
switch - No resistance across it when switch pressed
switch to R306 Resister - No resistance between
R306 Resister - 27K ohm as it should be
C310 capacitor - donno how to test that!
is there anything else i can try or have i missed something?
thanks,
Lad.
k310i. CID49 flashing 'n unlock OK but cannot turn on danau_ranau SETool2 1 01-12-2009 15:49
W300i - flashing OK - but won't turn on mahcin Cruiser Suite 5 05-23-2008 23:59
6100 flash ok, but not power on, please help kaholukkk Nokia Hardware & Hardware Repair 3 08-23-2006 17:37
6100 Flashing Ok But No Power On celluniversal Nokia Digital Core Technology 4 ( DCT-4 ) 1 03-01-2006 15:34
Page generated in 0.17037 seconds with 9 queries
