04-29-2002, 19:30 | #1 (permalink) |
No Life Poster Join Date: Feb 2001 Location: PH
Member: 3468 Status: Offline Thanks Meter: 308 | 3310 "all four locks closed" I tried everything - change cobba IC,change flash IC,NK-CALC,upgrade ver. but no success - always four locks closed EEFFEEFF. I also try to repair it rolis 1.7, message appear "Bad Cobba Signature". Any solution!? Thnks.... Rex, |
05-01-2002, 09:23 | #5 (permalink) |
Freak Poster Join Date: Dec 1999 Location: Earth
Member: 751 Status: Offline Thanks Meter: 19 | @Rex If nk_calc says cobba id:00000, then I suggest to recheck cobba installation (soldering balls, broken pcb, etc. ) that's ussuming you already changed it with new one. I always solve this kind of problem by changing cobba chip and using nk_calc or rolis v1.7 to update afterwards. Br, |
05-01-2002, 13:46 | #7 (permalink) |
No Life Poster Join Date: Jan 2002 Location: 24° 51′ 36″ N, 67°
Member: 8353 Status: Offline Sonork: 113276 Thanks Meter: 335 | try eepromtools first flash your phone with another software of different version then run eeproomtools 3 on this phone...your problem will be solved |
05-03-2002, 09:39 | #8 (permalink) |
Junior Member Join Date: Aug 2001 Location: Philippines
Member: 5626 Status: Offline Thanks Meter: 0 | 1.upload your original flash or another working flash that is the same or atleast 2 versions newer than yours. 2.check it with rollis 1.7 if you have msid usually starts with 83 not zero 3. if you have the right msid, go to logger 1.6 save your log file and then use tek logger to update your faid. do not use the rollis for updating your faid this time. 4. read it again if you still have the correct msid then this time you can now click on "clear SP locks" on rollis software then update your faid from rollis. Restore the correct msid first before unlocking your phone, otherwise you will always a have wrong msid. Thats how i solved this problem when I encountered it before. |
"all locks closed" keeps coming back | eureka8888 | Nokia Hardware & Hardware Repair | 1 | 09-22-2002 18:00 |
3310 "all four locks closed" | Rex | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 04-29-2002 19:28 |
3310 All Four Locks Closed Solution | datalife2000 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 04-04-2002 00:31 |
3310 4.18 four locks | domino | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-22-2001 00:08 |
3310 418G four locks closed viper help! | qtboy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-05-2001 11:49 |
