3310 auto shut off. Pls. help Hi... I have a 3310. When I turn it on... it turns off by itself after a few second. I'm a newbie in celphone repair. Can you please help me where to begin and how to fix the problem. Thanks. |
Check the battery,battery connector and if not sucessfull then Flash the phone. |
Reflow the cobba ... Br Ionel. |
try to clean the board with ultrasonic cleaner, if still try to change the CCONT BR Unggul |
The problem can be the pf , if it stops when is going to enter in network means that the pf is damaged and u hawe to change . |
check ur battery connecter and power switch |
before u change power ic n etc, u can check cristal ic 26 MHz n cristal clock |
check the battery and power amp |
try to replace antenna switch.......... post result, |
try to change battery sir,, and check it if it is shorted then if it is,,, then try to replace PA, |
pls change the power sith Quote:
bro pls change power swith :o:o:o:o:o:o:o:o |
