11-28-2001, 02:20 | #1 (permalink) |
Junior Member Join Date: Nov 2001 Location: Czech Republic
Member: 7642 Status: Offline Thanks Meter: 1 | 3310 Charging problem |
The Following User Says Thank You to AIR-tech For This Useful Post: |
11-28-2001, 09:35 | #2 (permalink) |
No Life Poster Join Date: Sep 2001 Location: London, UK
Member: 6486 Status: Offline Sonork: 100.79846 Thanks Meter: 350 | hi,<br />check charging ic... or replace that <br />regards<br /> <img src="eek.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="eek.gif" border="0"> |
11-28-2001, 12:32 | #3 (permalink) |
Freak Poster Join Date: Feb 2001 Location: Cj,Ro,Eu
Member: 3262 Status: Offline Thanks Meter: 1 | [quote]Originally posted by AIR-tech:<br /><strong>Hi,<br />I have unusual problem with 3310 but till now I have colected 4 pieces with same problem. When I put 3310 in to charger it says "charging" and it starts to charge then after 1 or 2 mins. it says again "charging" and stops charge. I tryed to change CCONT, Charge BGA, termistors and nothing helped. In NOKIA servis told me my friend that the same problem occured by 3330 and it was caused by bad flash chip, but today I changed flash + full backup and nothing. HELPPPP</strong><hr></blockquote> HI!<br />TRY TO CHANGE BATERY!<br />THE GOOD ONE ARE THE CHECH BATERRY.<br />MY BEST REGARDS |
12-11-2004, 13:47 | #4 (permalink) |
Freak Poster Join Date: Jan 2004 Location: Islamabad, Pakistan Age: 42
Member: 48857 Status: Offline Thanks Meter: 31 | just try to check the shortage among two points near the 6 key of keyboard. They r upside the key. If they r not shortened then short them and the problem ll be solved |
12-11-2004, 13:51 | #5 (permalink) | |
Freak Poster Join Date: Aug 2004 Location: f dewana Age: 43
Member: 79056 Status: Offline Thanks Meter: 149 | hi frind Quote:
try to change the connector or the problem in charger ReGarD Haidour | |
12-12-2004, 03:38 | #6 (permalink) | |
Major Poster Join Date: Jun 2004 Location: Lagos Nigeria
Member: 69977 Status: Offline Thanks Meter: 2 | Quote:
this is a diagram[pic] for not charging and self charging here:: http://forum.gsmhosting.com/vbb/atta...achmentid=7423 | |
12-12-2004, 03:43 | #7 (permalink) |
Member: 69977 Status: Offline Thanks Meter: 2 | it is wire solution original post by[ mohammad2004 ] or u can go to this thread::: http://forum.gsmhosting.com/vbb/show...1&page=1&pp=15 by [keany] |
02-11-2005, 15:16 | #8 (permalink) |
Freak Poster Join Date: Sep 2004 Location: Hellas Age: 47
Member: 83893 Status: Offline Thanks Meter: 1 | did u solve your problem friend? I ve changed ccnt chaps L201 c201 checked fuse and v205, checked r200...is there anything else i should try? contacts near key 6 are shortened alright but charging stops after a while...already tried with several batteries..please help me |
02-19-2005, 03:52 | #9 (permalink) |
Junior Member Join Date: Feb 2005 Age: 44
Member: 118630 Status: Offline Thanks Meter: 0 | pwer faliur3310 beginner i have nokia 3310 that fell into water ,i tried my best but not good enough phon stil blink when ever i press d power key and off on releas pls can any one help Last edited by amki; 02-19-2005 at 04:07. Reason: massage is dobble |
02-19-2005, 04:03 | #10 (permalink) |
Member: 118630 Status: Offline Thanks Meter: 0 | pwerfaliur3310 [QUOTE=amki]beginner i have nokia 3310 that fell into water ,i tried my best but not good enough phon stil blink when ever i press d power key and off on releas i have wash the pannel very well , heat it yet nothing seems to work.nokia 3310 no power |
3310 charging problems | Hanukkah | Nokia Hardware & Hardware Repair | 3 | 05-18-2005 15:06 |
3310 Charging problem | Vicky | Nokia Hardware & Hardware Repair | 5 | 10-14-2004 18:59 |
3310 charging problem | SubTen | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-18-2001 09:37 |
3310 charging problem | garcea10ro | Nokia Hardware & Hardware Repair | 2 | 10-24-2001 16:07 |
3310 charging problem | pornopig | Nokia Hardware & Hardware Repair | 5 | 10-08-2001 20:37 |
