Old 05-09-2002, 21:29   #1 (permalink)
Member: 4675
Thanks Meter: 7
5110 very hot under charge ic "not charging"
1 have experienced 2 5110 "not charging" display on screen. when i connect it to charger, it is very hot under the charging ic (other side of the board), i have check the fuse, change the hot part, still the same...
thanks
Old 05-15-2002, 01:26   #2 (permalink)
Hanukkah's Avatar
Member: 5246
Thanks Meter: 9
have you changed the Charging IC? Also replace the coil and varistors below the charging ic.
Old 05-17-2002, 21:52   #3 (permalink)
Member: 4675
Thanks Meter: 7
can u pls specify part numbers... i have change the flash ic, thanks
Charging not supported" and "Not charging" in BB5 phones .:NOYON.: Nokia Hardware & Hardware Repair 2 11-06-2008 22:25
C5-2 Very Hot When Charging biscotte Sagem Hardware Repair Area 2 06-20-2006 19:04
6230 "not charging" after 15 mins of charging .. ?? TRABEL Nokia Hardware & Hardware Repair 5 05-23-2006 10:52
8210 charge 10seconds than "not charging" error crossings Nokia Hardware & Hardware Repair 3 12-06-2003 15:31
Nokia 7110 "not charging" Sekoel Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 07-11-2001 12:01
Page generated in 0.15658 seconds with 9 queries
