3310 has diferent MSID on each powering on I have 3310 that shows diferent MSID after each powering on . Ofcause all 4 locks are closed . And i already tryed to change COBBA , phone works the same way as before :( Any ideas ? Thanks in advance , Mnm |
Flash - did you flashed it? If not, try, if yes, change flash IC. |
Yes i was trying to flash phone earlyer , but phone was working the same way . I just soldered flash IC from other 3310 and phone still shows diferent MSID after each powering phone on . Software by Rolis after reading phone gives message "Wrong Cobba ID" , and Dejan`s software says something similar to "Not known MSID , maybe this is new phone model" . |
1.first make full factory reset, after read your phone . always after reset You will see the same MSID. 2.reflash and update faid... 3.try to rehot it. |
HI try to flash the phone with a vergin eeprom & calculat faid regards fantom_105;) ;) ;) |
