3310 interesting FLASH IC Hi, i have one 3310 with flash problem... Phone can be flashed, but after flashing in flash ic is only trash. I already tried to change flash ic, ccont, RAM.... interesting is that if i send only small data(for ex. 65KB) in flash ic and then stop flashing, it is ok! But if i leave flashing till the end it will corrupt these data! Any Idea? Platy |
What do u mean??? After flash then ur flash IC become a defective flash IC? How can u know data in flash IC were corrupted. After U flash the flash file, read it back and then compare the files or what ? |
maybe ......... maybe not only flash rom occupies the DATA bus , ( maybe RAM at same time) this can corrupt flash data ( and can corrupt even flash IC ) , for me was such case in 3410 ..... Regard's |
if i flash only small data and then stop flashing in phone it is ok! i can read it back correctly! but if i won`t stop flashing and wait till the end of flashing whole flash then data would be corrupted - if i read it back it is corrupted! I already tried to change RAM... Platy |
I have this prob. in nokia 3210 and i solve it by change NEW IC FLASH and the phone work Fine Try |
BR, Djo |
Or change the flash IC with one that is programmed with good stuff (from a working 3310 that can be flashed correctly) . |
I already solved my problem, thanx it was CPU problem, i changed it and everything is ok now! ;) platy |
