08-27-2003, 21:16 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: lekka!!! Age: 51
Member: 12571 Status: Offline Thanks Meter: 1 | 3310 LCD problem!!! Tried new LCD same problem. Replaced Caps 409, 410 on top of board, same result. Any one have the same problem or can help with this one. Phone was water damaged!! Thanks |
08-27-2003, 21:56 | #2 (permalink) |
Freak Poster Join Date: Feb 2001 Location: South Africa
Member: 3355 Status: Offline Thanks Meter: 1 | had this problem twice.... once it was the ccont and the other time it was the cobba. I know this mite not make sense... but after butheading my self trying to figure out wtf else could be the problem... i figured, what do i have to loose by trying to replace either... and guess what... it worked! |
08-27-2003, 23:31 | #4 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Europe Age: 54
Member: 24581 Status: Offline Thanks Meter: 87 | Yes you change capacitors 409 and 410 but do you check does exist litle wire inside PCB from pins 2 and 8 LCD and this capacitors???Use service manual and see careful did i said right or use one PCB which is OK and check my words...... |
08-28-2003, 00:50 | #6 (permalink) |
Member: 24581 Status: Offline Thanks Meter: 87 | no,you must have conections betwen pin 2 of lcd and one capacitor and pin 8 lcd with second capacitor,use service manual and where is lcd part,or simple way use one board which is ok and multimeter and measure my "words",belive me |
08-28-2003, 01:04 | #8 (permalink) |
Member: 24581 Status: Offline Thanks Meter: 87 | FEVERDI check my solution and solution of Studio GSM..... mail us regards to Studio... from Poland (because my girl is from Checoslovakia wery close to you hahahaha) mp |
08-29-2003, 01:24 | #10 (permalink) |
No Life Poster Join Date: Jul 2001 Location: RP Age: 48
Member: 5246 Status: Offline Thanks Meter: 9 | That is line cut from 4 lcd pad from right. It has to be jumpered to some 1 jump point in jump point clusters upper right of #5 keypad. Use another board for comparison. This line is going to CPU. |
3310 lcd problem | chiefonline | Nokia Hardware & Hardware Repair | 9 | 12-07-2008 08:33 |
3310 lcd problem | ZEBUN | Nokia Hardware & Hardware Repair | 0 | 03-23-2005 09:50 |
3310 LCD problem | dazexy | Nokia Hardware & Hardware Repair | 1 | 12-12-2003 18:52 |
3310 LCD Problem | luminousblack | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 02-28-2002 19:45 |
3310/8210 lcd problems... | nnarta | Nokia Hardware & Hardware Repair | 1 | 02-14-2002 04:13 |
