3310 no displey???? I have one nokia 3310 only with light on the displey.<br />Anybody can help my!! Thanx <img src="frown.gif" border="0"> |
check lcd connector, if still doesnt work try replacing lcd.. Regards! |
also clean the lcd contactes .... |
[quote]Originally posted by Moc:<br /><strong>also clean the lcd contactes ....</strong><hr></blockquote><br />all is ok |
Display is probably dead.If You don`t have new one,use it from 3210.It is the same display. |
if display ok check for any dry joints around user interface |
change lcd if u dont have same lcd try 3210 lcd |
ewyting is ok<br />I put working display from another phon and thid don¨t work |
The LCD not working means hardware or/and software problem.<br />01- The Hardare prob is the LCD and it's connectors, capacitors on the LCD, the board connection,...<br />02- The software prob is resolved by flashing your phone ( full flash ) with a higher version to upgrade it. and you unlocked it if it is from the begin locked...<br />Add all will be fine. Thanks from a new helper |
