Old 06-03-2006, 11:54   #1 (permalink)
~mr_Ten$ion~'s Avatar
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
6600 dead ??
hi i have prob in 6600 .. when i changing its bluetooth module .. i change it now the prob is PHONE IS DEAD ... i again remove it & check but the fone DEAD ... any Solution in this forum to help me... customer on my head?? plz help
Old 06-03-2006, 12:01   #2 (permalink)
Member: 38276
Thanks Meter: 35
6600 must power on whidout bluetooth module..maybe is shorted..remove it and try to power on the phone whidout bluetooth...
Old 06-03-2006, 12:09   #3 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
yaa i remove it but sme point is shorted i mean bluetoth module jack .. its uper 2 to 3 points r connected wid each other ..can u tel me if bluetooth jack points is connect wid each other dis is also cause by dead .. when i remove the sorder wid these points its break the place i thk .. any other solution plz help .. BR
Old 06-03-2006, 12:44   #4 (permalink)
Member: 38276
Thanks Meter: 35
yes it is OK. the 3 and 2 upper points is shorted and connected to GND...
but you try to power on the board whidout bluetoth module? if not power on whidout maybe you broke the PCB....
Old 06-03-2006, 12:59   #5 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
so if i broken PCB so any solution ???
Old 06-03-2006, 13:05   #6 (permalink)
Member: 62321
Thanks Meter: 35
problem in uem change uem
Old 06-03-2006, 13:11   #7 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
wht how now prob in UEM ... now it posssible my board is shorted now UEM is bad.. its ntt a perfect solution ...?? plz any1 now abt it or any1 tested a solution plz guide me??
Old 06-03-2006, 15:35   #8 (permalink)
Member: 38276
Thanks Meter: 35
Man, for your problem there is no tested solutions! Tested solutions exist only for specific problems ( charging, network, lights etc). Your phone was alive and when you removed the bluetooth module you burned or broke something! But something what??? If you burned the PCB - no solution put the phone on recicle bin. If you hot too much the PCB probably you unsodered something else on other side of PCB... Thaths all...
Old 06-03-2006, 16:02   #9 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
i thk u rite>?? my fone is gone ???
Old 06-03-2006, 16:41   #10 (permalink)
Member: 225425
hello im beginner in mobile repair ccan anyone help me how to fix gallery problem for nokia 660o?
Old 06-03-2006, 17:04   #11 (permalink)
gsm-decode's Avatar
Member: 47441
Thanks Meter: 14
You can't imagine what u can do with hot air!
Old 06-03-2006, 18:50   #12 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
yes for sure ur phone goneeeeeee
check if pcb is still short ?
check on batt terminal with multi meter
and check when u put batt set heats up or not???
check and post reslut
Old 06-03-2006, 19:17   #13 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
No man its nt heat up .. when i check it on metter its nt shorted ... & when i put it on power supply when i press power button give up sme ampair .. so No Shorage ... NO heatup but its dead ... so i thk i lose my fone 99 percent ... any idea SHAHJEE ??
Old 06-03-2006, 19:29   #14 (permalink)
Member: 138809
Sonork: 100.99886
Thanks Meter: 79
u tried to flash phone???
try and post log
hope u could alive back phone
Old 06-03-2006, 19:36   #15 (permalink)
Member: 135601
Sonork: 100.1612518
Thanks Meter: 68
But man its cant detect it na this is the prob .. i cant understand .. its Not shorted ..its nt heated & its nt detect it for flashing .. so i thk when i heat the bluetooth madule on his oppist side i mean front side the main IC down the bluetooth madule i thk its broken??
now any idea???
br
nokia 6600 dead taking flashing,but still dead sandeepmtc Nokia Hardware & Hardware Repair 0 08-24-2007 17:53
6600 flashing error now 6600 dead kabeermaster25 Nokia Hardware & Hardware Repair 25 04-08-2006 02:31
6600 dead.......... zdob Griffin 16 11-08-2004 09:38
6600 dead after flashing with new 4.09.1 mohd_anan WD2 & APE (Symbian Phones) 7 04-26-2004 06:55
6600 Dead marukiaro Nokia Digital Core Technology 4 ( DCT-4 ) 7 02-24-2004 00:26
Page generated in 0.22164 seconds with 11 queries
