Old 08-18-2005, 06:23   #1 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
Angry 6670 phone start up failed contact the retailer
6670 phone start up failed contact the retailer i erase & flash with UFS 9 to 10 times version 4 & 5 flash & pm but still showing contact retailer pls. help me
thanks
shri
Old 08-18-2005, 07:11   #2 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
how about format user are? is it completed?
Old 08-18-2005, 10:09   #3 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
thanks
shri
Hi,
This is same problem with 7610. U can use search button to find for this solution!
B.R
Vinh Hai
Old 08-18-2005, 21:46   #4 (permalink)
Member: 167243
you cane change the cristal flash room no 1 or heeting it ......tested
Old 08-20-2005, 00:11   #5 (permalink)
Crazy Poster
Member: 86496
i THINK YOU NEED TO DO FORMAT USER AREA,AND YOUR PROBLEM IS SOLVED.
Old 08-21-2005, 22:49   #6 (permalink)
TechPhone's Avatar
Member: 41672
Thanks Meter: 195
6670 phone start-up failed. contect retailer
flashing so many times with Dctx_UFS_1.3k & try to full erase & after flashing pm writing, unlock
Set UI Factory Defaults Ok, Time: 00:07
Set Full Factory Defaults Ok, Time: 01:23
Set Software Upgrade Defaults Ok, Time: 00:00
Set Security Ok, Time: 00:00
IMEI: 355023-00-394320-9, ASIC: 5
SimLocks Initialized, Time: 00:12
all ok at last format user area done but same sowing contect retailer
pls. help me.
thanks
Old 08-21-2005, 22:53   #7 (permalink)
ANoNYMoUS_1's Avatar
Member: 153299
Thanks Meter: 59
format user area........
Old 08-22-2005, 03:12   #8 (permalink)
VinhHai's Avatar
Member: 34310
Thanks Meter: 23
pls. help me.
thanks
Wow, this is very old solution !!!! Why don't u use SEARCH function in forum to find it?.
Format by manualy:
Power the phone off
Press down talk(green) + 3 + *
Power the phone on
If u make correctly u will see "formatting..." And when format finish u can use ur phone normaly.
B.R
Vinh Hai
The Following User Says Thank You to VinhHai For This Useful Post:
Old 10-23-2006, 05:47   #9 (permalink)
Member: 118190
Thanks Meter: 4
Thumbs down
stupid solution!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!! most of us know that is HW problem!!!!!!!!!!!!!!!
Old 10-23-2006, 12:34   #10 (permalink)
Bagscom's Avatar
Member: 319976
Thanks Meter: 14
try to format Press Call*+3 power on if not wort maybe iits ueme problem.
Old 10-23-2006, 19:06   #11 (permalink)
Member: 299818
format by (power+3+ *+call)
Old 10-24-2006, 15:14   #12 (permalink)
Member: 193652
Ok I Will Give You The Right Solution For 7610 Contact Retailer ... You Must Format The Phone If It Did Not Whorking You Must Replace The Ram Black Or Som Time If You Heet The Flash It Whork
Old 10-25-2006, 03:00   #13 (permalink)
Member: 83879
Thanks Meter: 4
thanks
shri
If mobile has not sw prob than in most cases its dryjoint of flashes.
put off both flashes,reball it, fix it again,format mannually.
tested many times in 7610 6670.
Old 10-26-2006, 04:14   #14 (permalink)
Member: 118190
Thanks Meter: 4
Smile
thanks
shri
1stly pls try to change that CRYSTAL RAM,if still the same then change the 64mb flash ic,most of it solve by this solution ,i tried . wish all the best
Old 10-26-2006, 05:09   #15 (permalink)
Member: 79823
Thanks Meter: 26
well i think you should do the hold key way like hold *3and send key and power on that will solve the problem no need for flashing and any dam box
N96 Phone Start-up failed Contact the retailer (security Test failed in reading) dmaetrey MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 02-08-2010 13:46
7650 Phone start-up failed .Contact the retailer. Impossible with Prodigy??? xbaert Federal One 11 04-23-2005 10:50
3650 Phone start-up failed .Contact the retailer sunrise gsm Griffin 4 08-21-2004 11:38
phone start-up failed. Contact the retailer Solutions13 Nokia Digital Core Technology 4 ( DCT-4 ) 0 11-13-2002 15:34
Phone start-up failed. Contact the retailer kenichi Nokia Digital Core Technology 4 ( DCT-4 ) 5 10-08-2002 08:47
Page generated in 0.21082 seconds with 9 queries
