3310 problem HI all I need help for many nokia 3310 when l read the phone with nokia falsher rolis 4.77 it going to read and quickly display "done" every once it try to read it display "done" I try to change Ccont, Hager,Flash,Ram with no answer from the phone Can anyone explain the problem With many thanks |
You need to flash it after changing and do the factory reset. |
I check the connection of the cable and phone it is O.K and this problem in many phone without solution thanks for help |
does this still happen, after you've changed them components? Have you tried using another program? check 3310 service manuel, for display, as theres a few capacitors (i think at the top of the board) which may of become dry joint... |
Thanks Thanks for reply I check all voltage it is O.K but the problem not solved yet |
how this problem started? |
The problem start the phone is o.k but the signal is not o.k i rehot Cobba and it work fine for 2 days suddenly it stop to power on again every time i read it displaying "done" thanks for help |
Your Problem Is 100% Solved here. Just check this out. Nokia 3310 Lcd Display ways Problem Mobile Repairing Picture Help If you like the post please HIT THANKS BUTTON |
3310 Quote:
