Old 10-01-2002, 22:10   #1 (permalink)
uu1dx's Avatar
Member: 7993
Thanks Meter: 40
3310 signal level jumping up to full and down to zero
Hi all, I got 3310 with a problem like in Ericsson 1018 etc :-)
network level is jumping up'n'down, it finds network and losing it again. what can I do with this?
P.S. When it get into network, it is able to make a call at 10-20% of cases and power output is OK.
Old 10-02-2002, 01:51   #2 (permalink)
hyper_wamir's Avatar
Member: 9398
uu1dx,
i have the same prob with a 33 b4
reflow cobba, hagar..
or to be sure use witesla first to check rx tx...
then decide what to do next...
br
wamir
Old 10-02-2002, 11:25   #3 (permalink)
fiZ
Registered User
Member: 9626
how with wintesla can i check tx and rx?
Old 10-02-2002, 17:01   #4 (permalink)
Keke's Avatar
Member: 12733
Thanks Meter: 26
100 % pa or antena swicth
Goodluck
Old 10-06-2002, 22:58   #5 (permalink)
Jackmaxo's Avatar
Member: 7934
Hi,
3310 signal problems is afamous problem, but plz view old posts, all is there....
Good luck
Old 10-08-2002, 14:49   #6 (permalink)
kenwood's Avatar
Member: 4588
Thanks Meter: 45
too uu1dx
hı members you can change to cobba ıc and aftercalculatıng nk calculator work %100
good work
kenwood
Old 10-10-2002, 18:33   #7 (permalink)
Member: 12869
Thanks Meter: 3
Replace B200 it works 100%, believe me
Old 10-11-2002, 16:09   #8 (permalink)
Member: 14792
look my friends..
there can not be the exact one solutions for these kind of problems..this problem is not only for 3310..it can be for all the mobile phones..But firstly the thing that you should do to be sure that software is fixed..Then for hardware,look if the pcb is clean or not.and then you are sure that rx is fine..look for tx fault...Before changing anything ALL SUPPLY VOLTAGES AND SYSTEM CLOCK / SLEEP CLOCK should be checked.Check the caps.and resistors around the uBGA chips and pa..mostly the faults are:rf pwr amp may be overloaded,pins of antenna switch should be checked because the base of this component is made by ceramic and can be broken easily.Then try phone with two band..(900-1800)and look if one of these are out of order the filters of these bands should be checked.And also you should follow the rf diagrams..dont forget this;firstly check the software before opening pcb..then be sure all the line and components are fine before changing or reballing uBGA chips..I know that this info is not enough but the summary is almost like this.thanks.....
__jero__
No audio fix for T616 to T610 and T610 to T616 - FOUND merwin Sony Ericsson 19 09-11-2006 21:04
Need gdfs file to convert T610 to T630 and T630 to T610 mayer Twisterflasher 4 10-12-2005 13:40
Page generated in 0.15528 seconds with 9 queries
