08-15-2007, 09:53 | #4 (permalink) |
Freak Poster Join Date: Aug 2006 Location: Wish Phone
Member: 331835 Status: Offline Thanks Meter: 64 | try to charge your phone if you see right side bar charge in the screen .that's line switch on/off problem if it's not ..try to reball or change it ccont ic |
08-15-2007, 11:01 | #6 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: IBADAN, OYO STATE, NIGERIA
Member: 319112 Status: Offline Thanks Meter: 164 | Quote:
1. CHECK THE POWER SWITCH FOR PROPER FUNCTIONING, AND THIS CAN BE DONE BY PUTTING THE TWO LEADS OF THE MULTIMETER TESTER ON THE UPPER AND LOWER LEGS OF THE SWITCH AND THEN PRESS IT. MEANWHILE, THE METER KNOB SHOULD BE AT CONTINUITY. IF YOU HEAR BEEPING SOUND, IT MEANS THE SWITCH IS OKAY BUT IF NOT YOU NEED TO CHANGE IT. 2. HOWEVER, IF THE SWITCH IS OKAY YOU NEED TO DO A SHUNT BETWEEN THE MARKED TERMINAL OF THE SMALL DIODE JUST BELOW THE BIGGER ONE BELOW POWER IC [CCONT] AND THE LOWER LEG OF THE SWITCH AND THAT IS ALL. | |
08-15-2007, 16:09 | #8 (permalink) |
Junior Member Join Date: Dec 2006
Member: 416676 Status: Offline Thanks Meter: 5 | hi,try to check voltage on switch:1,8v before the switch pressed,and 3,6v after the switch is pressed,otherwise you have to check the line between the power switch(+) to power ic E4# |
08-15-2007, 23:44 | #9 (permalink) |
Freak Poster Join Date: May 2006 Location: mumbai..9892136479
Member: 275451 Status: Offline Thanks Meter: 84 | If The Switch Is Okay You Need To Do A Shunt Between The Marked Terminal Of The Small Diode Just Below The Bigger One Below Power Ic [ccont] And The Lower Leg Of The Switch And That Is All. |
1110 power on in ufs but not power in battery.what is the problam? | BERMODA_79 | Nokia Hardware & Hardware Repair | 10 | 01-13-2010 22:38 |
help..3230 power on ufs but not in battery | CHAPRAN | Nokia Hardware & Hardware Repair | 10 | 02-14-2007 11:59 |
1110 power on in ufs but not power in battery | CHAPRAN | Nokia Hardware & Hardware Repair | 12 | 02-05-2007 07:22 |
3230 on with ufs but not with battery | prnc | Nokia Hardware & Hardware Repair | 0 | 10-12-2006 21:52 |
1100 on with ufs bt not with battery | irfaN_vu | Nokia Hardware & Hardware Repair | 7 | 07-05-2006 14:51 |
