Old 07-20-2004, 18:57   #1 (permalink)
*Overseasunlock*'s Avatar
Member: 46602
Sonork: 100.61437
Thanks Meter: 7
3310 while flashing showing unknown flash id
hi
3310 or 3315
problem dead ,contact service
while flashing it is showing unknown flash id
what is the problem
pls reply
Old 07-20-2004, 19:06   #2 (permalink)
Member: 18057
Thanks Meter: 64
Originally Posted by ritesh kumar
hi
3310 or 3315
what is the problem
pls reply
first which soft u use for flash, conform con... ser... in eeprom or in mcu,ppm
if in mcu ,ppm then use griffin 100% accept any one flash id. in rolis or knok
u must edit config new id. or all prob.... in new productions . like v .6.33
right ?? if in eeprom so i m sorry cause i also dont have any solution for write eeprom in knok or in rolis. or u want to remove son... ser,... then change your flash ic or unlock it . working good.
b.r.
akki
Old 07-20-2004, 21:11   #3 (permalink)
Unggul's Avatar
Member: 71273
Thanks Meter: 14
100% flash Ic's damage
rehot flash Ic's or change it, use nokia tool if you change the flash ic's. 100% worked
Old 07-21-2004, 09:13   #4 (permalink)
DEVILvn's Avatar
Member: 37678
maybe you uses tool old
Old 07-21-2004, 12:05   #5 (permalink)
Member: 45635
Thanks Meter: 20
when you get this message unknown flash id or flash id = 00000000 you must rehot that ic or its better to change it . you will find that ic above flashrom ic ......
Old 07-22-2004, 00:43   #6 (permalink)
babaphone's Avatar
Member: 36751
Thanks Meter: 34
Your solution
Hi,
U r right Nokia has changed the flash I.C of new 3310 stock,fULLflash your mobile with GeoFlash ,u can download Geoflash from my gruop after joining it;
http://groups.yahoo.com/group/babaphone/
Babaphone-KuWAIT.
Old 07-22-2004, 07:01   #7 (permalink)
Member: 18057
Thanks Meter: 64
thanx very much for this help.
b.r.
akki
Old 01-19-2008, 09:05   #8 (permalink)
Member: 420730
how can i replace if the 3310 is shorted?
Old 01-19-2008, 09:07   #9 (permalink)
Member: 420730
Thumbs down
how can i replace if the 3310 is shorted? plz reply...
Old 01-19-2008, 09:08   #10 (permalink)
Member: 420730
what?............................................. ...................
Old 01-19-2008, 09:12   #11 (permalink)
Member: 626716
Thanks Meter: 16
replace at least sureball flash ic!100%working...
3310 Unknown flash type.flash ID.00000000 Mia Cellcom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 03-03-2005 10:22
2100 unknown flash type ( flash id 000000 ) Byte Nokia Hardware & Hardware Repair 5 07-31-2004 10:03
Page generated in 0.16479 seconds with 9 queries
