06-25-2002, 23:38 | #1 (permalink) |
No Life Poster Join Date: Jun 2002 Location: Iran Age: 47
Member: 12724 Status: Offline Thanks Meter: 30 | 3310aoutocharging I have a problem with 3310 wich after disconnecting the charger it chareges automatically. I have to mention it had water damage and I cleaned up the board compeletly. Plaese tell me what should I do. Thanks in advanced. LIGHT |
06-28-2002, 08:09 | #5 (permalink) |
Junior Member Join Date: Apr 2002 Location: Karachi Age: 53
Member: 10927 Status: Offline Thanks Meter: 0 | first try to clean you pcb with thiner, put it under 100w bulb for 5 minutes, if fault is as is, then put small amount of good quality flux near ccount and charging ic (smallest is, bottem left) and reflow with hot air, clean pcb then dry with bulb or hotair gun then check it, your problem should be fixed other wise replace charging ic |
