06-23-2004, 19:06 | #1 (permalink) |
Major Poster Join Date: Feb 2004 Age: 51
Member: 51849 Status: Offline Thanks Meter: 2 | 3315 blank LCD = strange !!! Reflash no helps. Change 2 little Chap & 2 big Chap no helps. Rehot CPU from other side no helps. With Voltmeter looks that voltage of LCD pins are WRONG. Pin 2 is 1.5 volts that should be 0 volts. Pin 4 is 1.5 volts that should be 2.8 volts. Please anyone expert help !!! I'm confused !!! |
06-23-2004, 21:31 | #3 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | @arif_tual: First of all tell us waht volage meter you have used. Osciloscope is recomendet.... Tell us some more details: Do contrast working..... Do you see complitly black screen... Do you see screen without contras? Do you se garbage??? |
06-24-2004, 01:53 | #4 (permalink) |
Member: 51849 Status: Offline Thanks Meter: 2 | Thanks for replies, @b0ba i use both digital and analog voltmeter, i still ordering an oscilloscope too ( on the way ), due i face many phones have rf component faulty. Contast : i haven't check it. Not black screen but looks clear bright ( almost no contrast at all ). I still be able to see Garbage ( do you mean a rectangular shadow ( very2 thin ) ? ) @azam I'll try that direct connection this afternoon.I'll post result I'm sure it's not water damaged, just pure hardware. But I hope not CPU cause it's Glued ( spending too much time ) Many thanks to all Regards arif Last edited by arif_tual; 06-24-2004 at 02:03. |
06-27-2004, 21:02 | #6 (permalink) |
Member: 6772 Status: Offline Thanks Meter: 17 | @arif_tual: Do not change PA. Wait till osciloscope will arrive. The correct sequance of dispaly comunication you can find in philips's datasheet. There are only few word abot LCD In nokia service manual. Full x86 asm code you can find here: http://forum.gsmhosting.com/vbb/showthread.php?t=125239 Check contrast voltage and D/C_(Data/Command) line.... Post a reply if you are missing something. |
j300 blank lcd, and lcd is good | johnny_liang | SonyEricsson (USB-Smart) | 1 | 05-10-2006 19:20 |
8210 blank LCD with good LCD and new | uwenk98 | Nokia Hardware & Hardware Repair | 5 | 03-19-2004 23:01 |
c45 blank display strange problem | thecult | Nokia Hardware & Hardware Repair | 2 | 12-16-2002 14:33 |
Ericsson T28 Blank LCD | YamahaR1 | Sony Ericsson Hardware Repair | 10 | 10-28-2002 16:59 |
G450 BLANK LCD AFTER FLASHING | nokya | Panasonic | 3 | 07-29-2001 20:24 |
