Old 05-03-2008, 19:30   #1 (permalink)
Member: 229124
Thanks Meter: 20
3500 charging not save
Show charging but battery not charged !
how to repair it ?
Old 05-03-2008, 21:26   #2 (permalink)
Member: 476697
Thanks Meter: 6
cheanging tahvo Ic....
Old 05-07-2008, 18:35   #3 (permalink)
Member: 229124
Thanks Meter: 20
i change tahvo but problem not soleved.
plz help me ?
Old 05-07-2008, 18:48   #4 (permalink)
mobylsolute's Avatar
Member: 587695
Thanks Meter: 61
how to repair it ?
connect the charger and change the battery and chk the voltage
on battery contact {below 1v that is not battery damage}
chk and result
Old 05-09-2008, 07:00   #5 (permalink)
Member: 229124
Thanks Meter: 20
without battery voltag on batery contact is 1.5v
Old 05-09-2008, 12:01   #6 (permalink)
mobilespeed's Avatar
Member: 706300
Thanks Meter: 147
re:
" bro u hav targeted the right suspect but hav u checked it with different charger & battery respectively, thanx"
Old 05-10-2008, 20:01   #7 (permalink)
Member: 229124
Thanks Meter: 20
i test with 3 battery and charger ! but battery not save charge !
bsi line valid in charge ? or v2000 ?
Thx
Old 05-11-2008, 22:41   #8 (permalink)
Member: 229124
Thanks Meter: 20
how to repair it ?
plz help me.
Old 05-12-2008, 05:50   #9 (permalink)
Member: 706300
Thanks Meter: 147
re:
how to repair it ?
plz help me.
" bro hav u checked the short if there is no short then try another tahvo, there is no other option to overcome the problem provided the unit shouldnt be short "
Old 05-13-2008, 21:41   #10 (permalink)
Member: 229124
Thanks Meter: 20
chenged by another tahvo and check short but problem not soleved !
Old 11-24-2008, 14:48   #11 (permalink)
Member: 635698
3500 charger not save
which is the tahvo ic plz 3500 charger not save
Old 11-24-2008, 15:03   #12 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
Thanks Meter: 5,700
i think it is tahvo ic version problem .......replace the tahvo ic with same version or with upper version ......version is wriiten on ic... check it...
good luck & post result....
Old 11-24-2008, 15:11   #13 (permalink)
..::ohm::..'s Avatar
Member: 662678
Thanks Meter: 2,539
cheak this and post
The Following User Says Thank You to ..::ohm::.. For This Useful Post:
Old 10-22-2010, 08:23   #14 (permalink)
Member: 697969
Thanks Meter: 8
how to repair it ?
first change the47k resistor below the simtray&check
nokia n73 showing charging but charging not save shree59 Nokia Hardware & Hardware Repair 24 04-11-2014 07:54
Nokia 6500c fake charging.charging not save solution mahbubalfa Nokia Hardware & Hardware Repair 12 05-08-2011 10:47
N95 8GB Charge ok but charging not saving buy_new Nokia Hardware & Hardware Repair 9 11-23-2010 14:18
x100 charging not save i chang charging ic but same shani72 Samsung Hardware Repair 0 03-31-2009 15:07
N95 8GB Charge ok but charging not saving urgent Adil Mobiles Nokia Hardware & Hardware Repair 8 10-08-2008 20:52
Page generated in 0.23449 seconds with 9 queries
