08-31-2003, 15:42 | #1 (permalink) |
Junior Member Join Date: Apr 2002 Location: Hungary Age: 37
Member: 11341 Status: Offline Thanks Meter: 1 | 3510 damaged by liquid |
The Following User Says Thank You to MDanny For This Useful Post: |
09-03-2003, 17:37 | #3 (permalink) |
No Life Poster Join Date: Apr 2002 Location: Radiometer Medical ApSBrønshøj Age: 51
Member: 10854 Status: Offline Sonork: 1578988 Thanks Meter: 3 | Hiya Check if there is connection between VBB (+ battery contact ) and R200... If not, solder a thin paint insulated copper wire and try again... This is most common case in liquid damaged 3510... There could be more faults, especially if You " rehot " all ICs on board... In future, try to avoid reheating all components...It is better to try to locate fault... If You have to rework BGA ICs, take it off, make new balls and solder it back...Just rehot won't give any result in most cases... BR Vule |
The Following User Says Thank You to vule For This Useful Post: |
Many Samsung Phones Damaged By Hi Voltage While Charging Solution | dannyogolo | Samsung Hardware Repair | 47 | 02-25-2011 17:54 |
Alcatel S-320......can not flash? :: DAMAGED BY OTHER TOOL UNLOCKED BY POLAR :: | husainm | PolarBox 3 | 20 | 05-30-2009 02:53 |
3510 unlock by Tweak 1.0 Beta2? | masterID | Nokia Multimedia | 2 | 02-10-2003 14:15 |
is it damaged by virualX sw really ? | makona | Panasonic | 2 | 06-02-2001 08:52 |
