Old 12-26-2003, 19:51   #1 (permalink)
Member: 37416
How to check Vbatt line?
I have a dead 3310
In service manual I am advised to check C404,C202,C226,C227,C228 if there is 3.6V on these cappacitors. I have 3.6 on C202( I can not find 404 on PCB) but I do not have 3.6 voltage on C227. The voltage on C227, when I measure it, drops from 3.6V and remains in 1,7 V. Why? ANd how can I check Vbatt line?
Thanks for help
Old 12-26-2003, 21:48   #2 (permalink)
Member: 39601
Thanks Meter: 13
Hi...
C404 is the smoother Cap of buzzer, it is under N400 the LED and
ring driver.
C227 is one of the smoothening Capacitors of the main line to the
ccont, the cause of the volt drop varies, it may be a leackage of 1
of the capacitors U mensioned , or failer of ccont it self or may be
it needs cleaning.
U can check the V-batt line by a mutimeter check the resistance
between +Ve and -Ve lines it must be higher than 1Mohm, and by
continuety meter check continuety between +Ve pin and other
+Ve points on the board ( buzzer pads, vibrator pads and Cap. U
mensioned ).
Old 12-27-2003, 13:49   #3 (permalink)
Member: 27606
Thanks Meter: 15
www.decoder.wz.cz
Old 01-02-2004, 08:07   #4 (permalink)
Member: 37416
Thanks a lot for help
HOW TO check bsi line luyanda Nokia Hardware & Hardware Repair 1 11-07-2009 12:19
How to check serial to know if i have to pay or not Millo_6 NSPRO 7 09-30-2009 01:26
How to check if the 3310 is shorted? (how to use multimeter for checking the line) sapatos Nokia Hardware & Hardware Repair 3 09-04-2005 10:33
GD55 sms how to create new line Fabmaster Panasonic 0 09-21-2004 10:51
HOW TO ACTIVATE 2ND LINE ON 3310 rigby Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 02-01-2002 03:40
Page generated in 0.16118 seconds with 9 queries
