06-05-2004, 20:13 | #1 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Ukraine. Lviv Age: 43
Member: 19633 Status: Offline Thanks Meter: 13 | 3510i not detect charger 3510i have no any reaction thet charger is pluged in. Fuze is Ok. Charger too. Where can by problem in thys case? Pleas help finde solution. Thenks |
06-05-2004, 20:17 | #2 (permalink) |
No Life Poster Join Date: May 2003
Member: 30098 Status: Offline Thanks Meter: 29 | What the response when you insert the charger ,and please use a couple of other charges to see what happens. Try flashing and loading good 3510i pm first, before trying any hardware on this. br |
09-01-2004, 16:38 | #4 (permalink) | |
No Life Poster Join Date: Jun 2002 Location: CT SA Age: 52
Member: 12733 Status: Offline Thanks Meter: 26 | Quote:
I have one here that doesn't detect charger @ all fuse is good , I full flashed the and pm also but still not working . Any solution for this?? Cheers | |
09-01-2004, 18:43 | #6 (permalink) | |
No Life Poster Join Date: Sep 2003 Age: 66
Member: 39601 Status: Offline Thanks Meter: 13 | Quote:
The v100 is a zinner diode with failure polarety of lets say (9v1/250ml-watt.). it lies at the circuit reversed ( anode to Grnd , and cathode to charging line ) .when the charging voltage increases than 9v1 that diode acts reversley to discharge the exess volt to ground and to keep the charging volt within 9v1/250 mw max. if the volt increases too much , and the total power exceeds the 1/4 watt limit , the diode collapses to short , so a short across the charging line and the Grnd appears. | |
09-01-2004, 19:07 | #7 (permalink) |
No Life Poster Join Date: Jun 2002 Location: *Portugal* Lisbon* Age: 45
Member: 13223 Status: Offline Thanks Meter: 59 | yes its true but i resolve many phones it only shunt solucion and no more problems if you put again diode after 2 months same problem grrrrrrrrrrrrr |
09-02-2004, 16:28 | #9 (permalink) |
No Life Poster Join Date: Mar 2003
Member: 24435 Status: Offline Thanks Meter: 4 | agree...uem short conected pins...resolder it...or change...check this: in atachment... If you have broken lead between r220 and next resistor and after wired phone not power on do steps abouve... |
04-08-2006, 17:18 | #12 (permalink) |
Freak Poster Join Date: May 2002 Location: Germany Age: 40
Member: 12274 Status: Offline Thanks Meter: 12 | dear Nokall..at so much posts in this forum("Posts: 544") don't you know the difference between "diode" and fuse? hahaha probably u are lost in the hardware section |
v220 not detect any charger!! | lucik | Motorola Hardware Repair | 46 | 10-31-2008 17:23 |
L6 Detects Charger But Not Charge | kwamena | Motorola Hardware Repair | 2 | 09-30-2007 19:05 |
7650 cannot detect charger | eivoig | Nokia Hardware & Hardware Repair | 3 | 02-12-2005 12:38 |
C45 does not detect charger | VREDNYJ | Siemens Hardware Repair Area | 2 | 08-28-2003 01:39 |
6150 detects charger but does not charge | Burnt Cobba | Nokia Hardware & Hardware Repair | 5 | 03-21-2003 21:09 |
