3610 flashing ok still cant power on Dear All I have problem with nokia 3610 I try reflashing phone with geoflasher and newknok reflashing ok! but still cant power on what the problem it........... :confused: :confused: :confused: regards |
Dear Gamma cell99 At Bekasi Jakarta you can convert your Nam-1 3610 to Nam-2 2100 Try This: Used Only Ufs-3/Tornado/Twister/N-Box Erase Flash Area 0X200000 To 0X600000 Then Re-Flashing With Nam-2 Used Firmware Only Version Nam-2 05.11 With PPm Usually 05.11F, After Flashing MCU+PPM You Will Get Contact Service, Do Rebuilt Imei,Init SIM Lock, Set Faid, Full Factory defaults It's Old Tricks.... Cause 3610 Have 32MB ic Inside...2100 Have 16MB... Half Capacity destoyed but Half It's OK........ But if still No power on after flash.... you must check the PWB/PCB line....On/Off Goes to Keymath_3_6_9 mostly missing circuit.... Good Luck Mate...... nb. Bekasi Banjir yah........ :) wassalam wiradinataR |
NO! Man....... My locations is bebas banjir lah you.......... usually jakarta always have buanjier trussssssss huakakakakak :D :D :D That the big problem my friend Im ufs-3 newest user im not to understand to use ufs-3 i :confused: :confused: I will expalin it to you in indoflasher ok! |
@gamacell99 just flash again with geoflash but u should use good flash files. or use griffin but u should flash eeprom too. btw kemana aja boss?? BR |
change flash chip , all done. |
terpaksa tenggelam gara2 tagihan MATRIX >32jt bos :( :( |
Phone work normal after changed with 8250 flash cip and reflashing with full flash file thanks to all friends BR |
