Old 08-06-2006, 05:25   #1 (permalink)
Member: 177298
Thanks Meter: 2
3650/60 New 4Blinks Solution
Hi m8's!
I recently just tried this solution for Nokia 3650/60 4 Blinks problem. I am using twister dongle. And just maybe, the supply is not enough for the phone to go in local mode when the status is 4 blinks w/o flashing it. But when i revised the cable and used a 9v batt, the local mode displayed even i didn't flash the phone.
I just did it like this:
1. Connect the cable to the 9v batt.
2. Connect it to the phone
3. Connect it to the dongle.
(at this point the "NOKIA" must be on the screen w/o the blinks, if not, just slightly press the power on button to let the "NOKIA" display.)
4. Format User Area, UI Default,..etc
5. Init Sim Locks
Just like that! I tried and tested it to 3650/60 whose problem is just SW!
I tried it maybe,.. more than 25 phones. Maybe it's not a 100% ok but, It'll be a lot of help!!
Pls post some response and reaction from experts in here!
*** SPEED!!
Old 08-06-2006, 05:38   #2 (permalink)
shinod's Avatar
Member: 55363
Thanks Meter: 146
password
please give me the pass word
Old 08-06-2006, 07:52   #3 (permalink)
Member: 322319
Thanks Meter: 4
Smile just flash it with the same version...
Originally Posted by remylebeau
Hi m8's!
5. Init Sim Locks
*** SPEED!!
twister or jaf box, its ok with the 4 blinks problem.... No need to worry...
Baby Rain
Old 08-06-2006, 07:55   #4 (permalink)
Member: 322319
Thanks Meter: 4
what is the password for that, i can't open the file...
Old 08-09-2006, 03:44   #5 (permalink)
Member: 177298
Thanks Meter: 2
oops..
its here again..
pass: [email protected]
Old 08-12-2006, 10:34   #6 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
schematics 4 that pic of yours ??
Old 08-14-2006, 04:26   #7 (permalink)
Member: 177298
Thanks Meter: 2
oops..
sorry for the schemeatics, 2moro I Post..
sorry again. newbie here..
Old 08-25-2006, 10:21   #8 (permalink)
Member: 177298
Thanks Meter: 2
here it is!
just try it. hope it helps!
Old 08-25-2006, 10:36   #9 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
are you out of your mind ?????!!!!!!????
HOW CAN U PUT 9V INTO A PHONE ???? INSTEAD OF 3.8V-4,2V ????
PROBLEM SOLVED ANYWAY ...WITH GRIFFIN
Old 08-25-2006, 15:29   #10 (permalink)
1amigo's Avatar
Member: 23587
Thanks Meter: 63
Dear jokkergsm, please share how you solved this problem with Griffin.
Old 08-25-2006, 16:38   #11 (permalink)
kindo's Avatar
Member: 300886
Thanks Meter: 61
This problem sometime of course came from dropping amphere and voltage. it is usually when we use laptop, old computer with usb 1.1 and computer with low power(watt) power supply.
Old 08-27-2006, 06:48   #12 (permalink)
Member: 177298
Thanks Meter: 2
it worked with me just fine. only in hang problem and 4 blinks. u can try it. im just sharing what ive tried and tested, and its 4 ppl who only owns twister boxes. =)
Old 09-01-2006, 17:30   #13 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
the problem was solved by griffin because with i twister couldn`t put the phone in local mode .... after local mode u can format user area, unlock etc
Old 09-02-2006, 06:25   #14 (permalink)
nuj
Member: 72392
Thanks Meter: 3
perhaps you can modify those old twister cables by connecting/inserting a 3.3k or 10k resistor between the BSI and the negative....so s to put the unit in test/local mode to do format user area...
Old 09-02-2006, 08:23   #15 (permalink)
jokkergsm's Avatar
Member: 8866
Thanks Meter: 50
i tried that ...it didn`t work
...(in my case at least)
Solution Contact Retailer 6600-3650-60/3230/7610 & 6260. king.of.gsm Nokia Hardware & Hardware Repair 0 12-12-2009 20:05
3650 net work 10000000% solution biniesh_08 Nokia Hardware & Hardware Repair 0 04-16-2009 17:03
3650/60 New 4Blinks Solution vinay_sharma Nokia Hardware & Hardware Repair 4 12-13-2007 14:02
6610,7250,3100,6600,3650/60 flash chip numbers cgsm Nokia Hardware & Hardware Repair 21 05-04-2007 12:00
Nokia 3650/60 pinnout schematics TetraUK UFS2 + UFS3-Tornadoflasher 1 10-20-2004 17:51
Page generated in 0.27983 seconds with 10 queries
