3650 flashing problem :confused: hello all I Have A 3650 With Below Mentioned Flashing Problem . I Have Done 3 Flashes , UEM , Ram's Reballing & Also Changed RTC & 26.000 Crystal . Can You Please Suggest Me What To Do Next To Remove 2nd Boot Error.... Regards - n - Thanks Sumit Lama +919872500161 1st Boot Ok, WD2, UPP: 0082 2nd Boot Error: 2 Platform: 6, Error Data: D3 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Process Failed, Repowering Mobile |
change ram not reball~~~~~ok:cool: change a new 1 not take from other board because this glass ic is esey damage |
service the panel with spirit then heat with reworks for a while then click on check reply if it dosent work |
hello all i have also reballed CPU today but the result is still the same ... can it be happen due to LCD problem ? also i put a new ram ic from a working plate ... but all in ??? regards - n - thanks sumit lama |
Please REPLY ALL :confused: Hello All Please Reply To Help Me Out Of This Problem :mad: |
