Old 09-01-2009, 15:22   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
..::1208 flashing error::..
1209 dead when try to flash it gives this error,i already reball flash ic but still same
MCU ID: 0x2292
Reading flash chip detailes...
FLASH ID0: 88720089 <=> INTEL -> Type not in database Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10
FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0
First 16 bytes: FF FF FE FF FF FF EF F7 FF FF FF EE FF FF E7 5F
MCU ID: 0x2292
Boot is ready...
Algo is ready...
Loader is ready...
Erasing area: 01000000 - 01FFFFFF...
Error erasing area: 01000000 - 0100FFFF
The Following User Says Thank You to HUM For This Useful Post:
Old 09-01-2009, 16:07   #2 (permalink)
syed tuqeer's Avatar
Member: 654997
Sonork: 1613804(Don't Spam Plz)
Thanks Meter: 4,073
MCU ID: 0x2292
MCU ID: 0x2292
Boot is ready...
Algo is ready...
Loader is ready...
no need to reball flash ic or any thing
just flash with easy cable
all will be ok. tested many time....
Old 09-01-2009, 16:29   #3 (permalink)
[ABDULLAH]'s Avatar
Member: 1021182
Thanks Meter: 39
First try it with 4.11 if no results then full erase and latest flash 5.53 1209 flash file
abdullah81
Old 09-01-2009, 20:08   #4 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
try with both easy and fbus cable but still same
Old 09-01-2009, 20:19   #5 (permalink)
togelmania's Avatar
Member: 468970
Sonork: M.G.T
Thanks Meter: 70
Remove flash ic...flash again,,if log still same your flash ic is okay but upp is weak..!!!!!!
Old 09-01-2009, 20:23   #6 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,237
ok i will try and post result
Old 09-02-2009, 02:48   #7 (permalink)
Member: 654997
Thanks Meter: 4,073
This is intel chip bro...........mostly gives error
1:-Erase
2:- full flash(latest ver) with easy cable
3:-write pm, unlock and do full factory setting.
try and post result..........
http://forum.gsmhosting.com/vbb/show...4&postcount=44
..::6600s flashing error::..[SOLVED] HUM MXKEY Nokia Flasher and Unlocker (by Alim Hape) 15 02-10-2010 09:55
..::1208 flashing failed but contact service::.. HUM Nokia Hardware & Hardware Repair 22 12-04-2009 10:31
..::1202 flashing error::.. HUM Nokia Hardware & Hardware Repair 5 07-21-2009 12:44
..::6280 flashing error::.. HUM Nokia Hardware & Hardware Repair 3 03-28-2009 20:52
.::v3 flash error::. rajabrotherscom Smart-Clip 3 05-20-2006 12:12
Page generated in 0.20431 seconds with 9 queries
