Old 09-15-2007, 08:08   #1 (permalink)
sachin_udai's Avatar
Member: 515100
Thanks Meter: 73
nokia 1600 mic does not work
hi sir nokia 1600 mic does not work mic is ok can some 1 post me the mic ways
thanx
Old 09-15-2007, 08:18   #2 (permalink)
Registered User
Member: 572549
Thanks Meter: 175
first check the mic if ok check resistor above mic terminal try reheat the resistor
Old 09-15-2007, 08:42   #3 (permalink)
Member: 515100
Thanks Meter: 73
that resistance is damaged with its print can u post me the mic ways or some jumper sol.
thanx.
Old 09-15-2007, 17:22   #4 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
1110 mic solution
hi,
1600,1110,2310,2610, 6030 can do .See the image.And just connect this two point. your problem is solved.
good luck.................
The Following 2 Users Say Thank You to sopnil For This Useful Post:
Old 09-15-2007, 18:29   #5 (permalink)
sopnil's Avatar
Member: 528679
Thanks Meter: 268
1600 mic solution
hi,1600,1110,6030,2610,2310 just do like picture.......
Old 02-15-2008, 03:55   #6 (permalink)
Mind Power's Avatar
Member: 338106
Thanks Meter: 55
1600 low mic voice what can i do pleas help me
Old 02-15-2008, 10:37   #7 (permalink)
Member: 562539
Thanks Meter: 3
low mic voice wash pcb point and mic points or change mic 100% solve ur problem
Old 08-27-2009, 19:22   #8 (permalink)
Member: 1042086
Sonork: nil
Thanks Meter: 2
2310 nokia mic very low voice plz help me
Old 08-27-2009, 22:36   #9 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.1st change good mic.........
if not ok try it............
The Following 2 Users Say Thank You to mahbubalfa For This Useful Post:
Old 08-28-2009, 20:42   #10 (permalink)
Member: 1042086
Sonork: nil
Thanks Meter: 2
thank sir 4 help me
thank sir 4help me fine work
Old 09-02-2009, 01:48   #11 (permalink)
Member: 1064047
Thanks Meter: 435
Nokia 1110 1600 >>>>>>>>>>>>>
Problem : mic does not work in xperia x1 celltellpb Sony Ericsson Hardware Repair 4 02-15-2011 05:18
nokia 1600 imei change not working? shh_903 Universalbox 1 02-11-2010 16:56
N93 mic does not work dawn bcn Nokia Hardware & Hardware Repair 6 03-01-2009 13:23
nokia 1600 power buten not work faisal_fs Nokia Hardware & Hardware Repair 0 11-16-2008 08:13
nokia 1600 some keypad not working barthosyn Nokia Hardware & Hardware Repair 5 06-19-2008 01:59
Page generated in 0.30568 seconds with 10 queries
