04-20-2002, 13:07 | #1 (permalink) |
No Life Poster Join Date: Jun 2001 Location: UAE Age: 43
Member: 5019 Status: Offline Sonork: 100.110196 Thanks Meter: 69 | 5110 very low network signal my 5110 has very low network signal, it's almost better, when using external antenna i changed external antenna connector,also shorted it, no result, any solution? Last edited by ARC; 04-23-2002 at 16:24. |
04-24-2002, 05:25 | #4 (permalink) |
Crazy Poster Join Date: Oct 2001 Location: Croatia, Zagreb
Member: 6960 Status: Offline Thanks Meter: 0 | Hello ARC, Can you tell me what you try to change it on your 5110? I have similar problem with 6110, but sometimes have good signal, sometimes low, but always can use it. Even if full dropped. I noticed that PA (power amplifier) probably do very hard work bacause it causes very loud noise in the FM radio in the same room. Did you noticed something similar with yours. Others mobiles never do so high noise. And after talk, usually, it immediately power off. I power it on and use it as usually. I will try to fix it in a few days (hard t find time ). So I will notice you. Regards, Nicos |
04-25-2002, 03:35 | #5 (permalink) |
Freak Poster Join Date: Feb 2002
Member: 9254 Status: Offline Thanks Meter: 4 | Hi Most hardware Rx level problems on 5110/6110 are caused by 13Mhz ceramic filter (Z620) cracking - replace this component. Hope this Helps Last edited by M@RTY; 04-25-2002 at 03:37. |
>>:: N86 network signal very low ::<< | saiftc2 | Nokia Hardware & Hardware Repair | 7 | 02-13-2010 19:23 |
2600 low network signal | .:SARCAR:. | Nokia Hardware & Hardware Repair | 2 | 09-09-2007 06:07 |
L2 very low network | vinkle | Motorola Hardware Repair | 0 | 05-21-2007 06:47 |
N6210 very low network level at 900Mhz | Disaster | Nokia Hardware & Hardware Repair | 8 | 01-23-2003 08:57 |
8210 very low Tx, Signal is good | CellM@n | Nokia Hardware & Hardware Repair | 1 | 10-21-2002 09:59 |
