Old 05-09-2011, 07:28   #1 (permalink)
Member: 277937
Thanks Meter: 48
5130 charger not supported
need solution of 5130 charger not supported i already replace r100. also remove bsi capas......
when insert charger after few secand show charge not support any tested solution ?
thx
Old 05-09-2011, 08:38   #2 (permalink)
imran zafar's Avatar
Member: 328187
Thanks Meter: 1,687
flash ur set (pm 309 field) check r2071(ntc).......if water damage then
replace r2010/c2012c2000........check shortage on bsi track.....if still
then replace 1st batty ic and 2nd avilma........post reply
Old 05-09-2011, 09:38   #3 (permalink)
Member: 277937
Thanks Meter: 48
set not water damage ...............
Old 05-09-2011, 09:48   #4 (permalink)
Member: 328187
Thanks Meter: 1,687
ok check reading on positive point of charger at board
if reading normal like a ok set then ......check ntc(r2071)or flash ur set
and check shortage on bsi ways check battery and charger also
if reading less then normal set then.....replace betty ic
if reading more then normal set then......check all those parts
they r direct attach with positive way of charger to ground ...include
betty ic
Old 05-09-2011, 10:46   #5 (permalink)
IRFANMOBILEZ's Avatar
Member: 1569848
Sonork: 100.1593338
Thanks Meter: 97
thx
try this bro.....
Old 05-09-2011, 11:35   #6 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
thx
Bro.Just Replace betty ic.
hope your problem will be solve.
Old 05-09-2011, 12:17   #7 (permalink)
mobilecitycbk's Avatar
Member: 475440
Sonork: 1604067
Thanks Meter: 965
try this
Old 05-09-2011, 13:30   #8 (permalink)
riyaz_deva's Avatar
Member: 565996
Thanks Meter: 13
not slove brodher 5130
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-08-2017 13:21
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
how to unlock 5130 accelr8 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-24-2010 17:52
winlock wintesla m2bus do not work Bigbrothers2000 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-26-2000 14:31
Page generated in 0.20412 seconds with 9 queries
