Old 08-21-2010, 07:59   #1 (permalink)
Arjun mishra's Avatar
Member: 426107
Thanks Meter: 64
Cool 3110c No RAP Flash Chip Detected
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.8929(24-06-2010), 1.0.0.14574(24-06-2010)
RAP Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM
ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 104000066C3B7E5619A91FDBA84CE1560BBF19F7
ASIC MODE ID: 00
ROOT KEY HASH: BAF3A9C3DBFA8454937DB77F2B8852B1
ROM ID: 191EC665DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision:
0.0 size: 0x3C00
Supported RAP Ids: 0103192101003000, 010C192101003000,
0103192101013000, 010C192101013000, 0103192101003100,
010C192101003100, 0303192101023000, 030C192101023000,
0303192101033000, 030C192101033000, 0103192101001101,
010C192101001101, 0003192101001002, 000C192101001002,
0013192101001002, 001C192101001002
TransmissionMode: 16Bit
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0
revision: 0.0 size: 0x22C10
0303192101033000, 030C192101033000, 0003192101002000,
000C192101002000, 0003192101002100, 000C192101002100,
0003192101002200, 000C192101002200, 0003192101012200,
000C192101012200, 0103192101001101, 010C192101001101,
0003192101001002, 000C192101001002, 0013192101001002,
001C192101001002
RAP PAPUBKEYS is blank/erased.
TransmissionMode: DDR&TX2
Original Imei: 00000000000000
Original Product code:
Old 08-21-2010, 08:09   #2 (permalink)
varunkumar143's Avatar
Member: 1304104
Thanks Meter: 9
brother i have same problem give anybody right solution pleaseeeeeeeeeeeeee
Old 08-21-2010, 08:36   #3 (permalink)
Member: 426107
Thanks Meter: 64
reboll rap ic problem solved by me.....
Old 08-21-2010, 09:03   #4 (permalink)
aZimBahar's Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 11,979
reboll rap ic or change
Old 08-21-2010, 09:04   #5 (permalink)
Member: 1304104
Thanks Meter: 9
i tried all give any new solution
Old 01-25-2011, 10:09   #6 (permalink)
Member: 1102270
Thanks Meter: 5
brother flash ic change it
Old 02-08-2011, 11:25   #7 (permalink)
Member: 776165
Thanks Meter: 14
Help me BRO,
2700c
Library version: 1.0.0.9169(08-01-2011), 1.0.0.15596(08-01-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x]
EM0 ID: 00000296
EM1 ID: 00000B22
PUBLIC ID: 2240010AD8914950C619EFD22CA7D821093AAAE4
ASIC MODE ID: 00
ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723
ROM ID: 273F6D55DFAAF68F
SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 1.30.0 revision: 0.0 size: 0x3C00
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
ID 32: 000110043434
Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 1.40.0 revision: 0.0 size: 0x22C10
Supported Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002
CMT PAPUBKEYS HASH: 3EA22A1DDA660002E56108DB5072A10F8709443F
Original Imei: 35154704780706
Original Product code: 0589277
Bluetooth ID: 5C57C865AF33
Phone Type: RM-561 (Nokia 2700 classic)
SW Version: V 09.95 02-04-10 RM-561 (c) Nokia
Imei plain: 35154704780706-5
Product Code: 0589277
Language Pack:
- not available.
This is SL3 phone(Simlock2 format).
- Avoid SW Downgrade & manual erase to this phone !
SIMLOCK seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SIMLOCK_TEST passed
SECURITY_TEST passed
Imei net: 351547047807065
Version: SIMLOCK SERVER
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
Old 02-08-2011, 11:37   #8 (permalink)
Moderator
Nizda Mobile's Avatar
Member: 1464783
Thanks Meter: 1,091
Originally Posted by dossdct View Post
Help me BRO,
2700c
CMT Data :
EM0 ID: 00000296
EM1 ID: 00000B22
ASIC MODE ID: 00
ID 32: 000110043434
Language Pack:
- not available.
SIMLOCK_TEST passed
Counter: 0/3, 0/10
why do you flash this phone,what is phone condition now?
Old 02-09-2011, 13:09   #9 (permalink)
Member: 1102270
Thanks Meter: 5
no rap chip flash not detected
first check your cable use the 7pincable than u can try it brother re hote flash ic & power ic 100% problem will be soled
Old 02-09-2011, 14:05   #10 (permalink)
idrish911's Avatar
Member: 1497850
Sonork: 100.1601368 QQID:21952428
Thanks Meter: 1,575
rehott flash cheap and retry to flash brother.........
Old 03-06-2011, 08:41   #11 (permalink)
Member: 1358404
Sonork: N/A
Thanks Meter: 47
Old 04-22-2011, 09:52   #12 (permalink)
Member: 622484
Thanks Meter: 5
nokia 3110c problem....
Library version: 1.0.0.9274(01-03-2011), 1.0.0.15761(01-03-2011)
CMT Data :
SYSTEM ASIC ID: 000000010000022600010006010C192101001101 [RAPGSM ver: 1.1]
EM0 ID: 00000232
EM1 ID: 00000353
PUBLIC ID: 169000077A827C5606338EC1C6CCB6F55B43CD4A
ASIC MODE ID: 00
ID 32: 000110000010
loader not responding (0200000000D172)
please help anybody.....
Old 04-22-2011, 15:26   #13 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 552
Rehot your flash chip and then try!!!
Old 05-14-2011, 10:59   #14 (permalink)
hossnemamun's Avatar
Member: 324750
Sonork: 100.1590437
Thanks Meter: 302
Dear Bro,
Chenge Capacitor on Power IC inside.
Thanks
Hossne Mamun
Old 08-24-2012, 12:54   #15 (permalink)
Crazy Poster
Member: 1413705
Thanks Meter: 4
tag any picture of this capacitor
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 08-16-2019 19:37
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 05:41
no one can unlock 6110 05.40 25-5-99 fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 09-22-1999 08:03
Page generated in 0.31842 seconds with 9 queries
