02-09-2010, 07:59 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: MX-KEY is the BEST NOKIA TOOL. Age: 39
Member: 747537 Status: Offline Thanks Meter: 39 | 5130 SECURITY_TEST failed!(contect service) RAP Data : SYSTEM ASIC ID: 000000010000022600010006030C192101033000 [RAP3G ver: PA 3.x] EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 17F001130CB48B565AAC388F98ECA22CCB0CFBA6 ASIC MODE ID: 00 ROOT KEY HASH: 9DDBFCFE6E73CED7D8C6268C8EB85723 ROM ID: 273F6D55DFAAF68F SecondaryBoot: rap3gv3_2nd.fg [BB5] version: 9.11.1 revision: 0.0 size: 0x3C00 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 FlashID0: 0089 8982 - 0000 8A31 [Intel NU48F512,512 Mbits] type: NOR,RAP ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000 ExtDEVC: FFFF 0000 - 0000 0000 Algorithm: RAP3Gv3_algo.fg [BB5 ALGORITHM] version: 9.17.0 revision: 0.0 size: 0x22E90 Supported RAP Ids: 0103192101003000, 010C192101003000, 0103192101013000, 010C192101013000, 0103192101003100, 010C192101003100, 0303192101023000, 030C192101023000, 0303192101033000, 030C192101033000, 0003192101002000, 000C192101002000, 0003192101002100, 000C192101002100, 0003192101002200, 000C192101002200, 0003192101012200, 000C192101012200, 0103192101001101, 010C192101001101, 0003192101001002, 000C192101001002, 0013192101001002, 001C192101001002 RAP PAPUBKEYS HASH: 0C917F11196FDB7378C18EF7260698CA4489DCA0 Original Imei: 35694403601840 Original Product code: 0577793 Bluetooth ID: 9C1874068D7D Phone Type: RM-495 (Nokia 5130c-2) SW Version: V 07.90 23-09-09 RM-495 (c) Nokia Imei plain: 35694403601840-5 Product Code: 0571584 Language Pack: - not available. This phone have PM308 protected, SD security in not restorable. This is SL3 phone(Simlock2 format). - Avoid SW Downgrade & manual erase to this phone ! SIMLOCK seems to be valid SUPERDONGLE_KEY seems to be valid SIMLOCK_TEST passed SECURITY_TEST failed! Imei net: 356944036018405 Version: SIMLOCK SERVER Provider: Nokia Test, Country: Finland Counter: 0/3, 0/10 CONFIG_DATA: 2440700000000000 PROFILE_BITS: 0000000000000000 BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF |
02-09-2010, 08:06 | #4 (permalink) |
Freak Poster Join Date: Jan 2007 Location: India.Pin.629001
Member: 433257 Status: Offline Thanks Meter: 43 | just write pm with sx4 auth ur phone will be ok never go for any other solution except security test every thing is ok with ur mobile |
The Following User Says Thank You to maximas007 For This Useful Post: |
02-09-2010, 11:04 | #7 (permalink) |
No Life Poster Join Date: May 2005 Age: 43
Member: 149032 Status: Offline Thanks Meter: 3,808 | use mx-key and 1st super dangal repair then super sd auth write pm and ok any help [email protected] |
02-09-2010, 12:24 | #9 (permalink) |
Freak Poster Join Date: Apr 2005 Location: MX-KEY is the BEST NOKIA TOOL Age: 44
Member: 133201 Status: Offline Thanks Meter: 74 | do sx4 and write pm but only 1 and 309 field or pm without 120 and 308 field with mxkey |
The Following User Says Thank You to khm050 For This Useful Post: |
5130c contect service.SECURITY_TEST failed | rafik2533 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 8 | 03-27-2010 14:25 |
Nokia 5130 RM-495 SECURITY_TEST failed! Video Manual | akashub | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 4 | 02-21-2010 05:38 |
Any Buddy repair SIMLOCK invalid!, SIMLOCK_TEST failed! or SECURITY_TEST failed! | mohit_kripalu01 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-06-2010 11:36 |
SECURITY_TEST failed!" and "warning: SD authorized but verify failed solution | ..::Rizwan::.. | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 2 | 02-03-2010 15:58 |
SIMLOCK invalid!, SIMLOCK_TEST failed!, SECURITY_TEST failed! | Raven21 | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 7 | 01-27-2010 08:15 |
