12-11-2009, 14:13 | #2 (permalink) | |
No Life Poster Join Date: Jul 2005 Location: ludhiana~india Age: 38
Member: 163833 Status: Offline Sonork: 100.1579554 Thanks Meter: 5,700 | Quote:
http://forum.gsmhosting.com/vbb/show...556022&page=11 if ur set is not shot then try to check it with any soft and if there is problem with flashing then post log here ... | |
12-11-2009, 16:11 | #3 (permalink) |
Freak Poster Join Date: Oct 2009
Member: 1150643 Status: Offline Thanks Meter: 40 | I've also experienced such problems. I'll tell you how to analyze it, who knows your problems with that I have ever experienced. step 1: <br>check the power supply current: <br>press on / off = o ma - 360 ma - 240 ma - 0 ma <br>the results of the current check known mob in short after press the switch <br>or konslet ic power at work. <br> <br> step 2: <br>* Looking for a short component: <br>- Search the shortCapasitor by finding the short component to gnd <br>two poles: - c2814, c2811 = VIO <br>- After a short components meet the output voltage line power ic <br>The next step in the VIO voltage injected Capasitor C2814 or C2811 <br>to set pelan2 in power supply voltage must not exceed 1.8 v. <br>- components hot or warm in a position in the injection voltage VIO <br>use power supply. <br>after feeling it ic bluethoot (BTFM module) N6000 warm. <br>- The next step up the warm N6000 and check back current. <br> step 3 : 1ST BOOT : C0,07 [Rm-303] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101013000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 16700210877A0254370E15BF0704907B6C807BA5 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 0001003F-00008A21, Amd 72NS512PD CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 3E96DE4212587183E5E16BB2C79692A53C19875D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile JAF version 1.98.62 Detected PKEY: 90009699 Card life counter: 99.99% P-key nokia module version 01.02 Detected JAF INTERFACE version: 01.B1, Driver version: 20416, Library version: 30118 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: Can't read USB Cable Driver version! Changing mode...Done! Booting phone... FAST PHONE detected! CMT Boot Data: Asic ID: 000000010000022600010006010C192101013000 Asic Mode ID: 00 Asic EM ID: 00000B22 Asic Public ID: 16700210877A0254370E15BF0704907B6C807BA5 HASH: BAF3A9C3DBFA8454937DB77F2B8852B100000000 ROM ID: 273F6D55DFAAF68F CMT Boot File: C:\Program Files\ODEON\JAF\Flash\rap3gv3_2nd.fg Loader version: 01.1E.00 -> Revision: 0000 Patching CMT boot step1... Patching CMT boot step2... Patching CMT boot step3... CMT Boot Ready CMT Flash ID: 003F0001 <=> SPANSION -> Type not in database CMT Flash Data: 00000000000000000000000000000000 CMT Loader: C:\Program Files\ODEON\JAF\Flash\RAP3Gv3_algo.fg Loader version: 01.21.01 -> Revision: 0000 Patching CMT loader step1... Patching CMT loader step3... CMT Loader Ready Done! Restarting phone...Done! info with jaf : Switching to serial... Powering the phone... Reading... Failed! Aborting! IMEI the end of the flashing error because the phone can not enter local mode. <br>try on the phone with a battery switch, burning the phone results <br>but at the time of loading the LCD blanks and direct current shutdown .. <br>try flash again with version 8.80 was the highest mobile phone <br>directly into local mode <br> <br>try to check and info: <br> 1ST BOOT : C0,07 [Rm-303] [2.0.9.0] RAPx ID : 000000010000022600010006010C192101013000 EM 1 ID : 00000295 EM 2 ID : 00000B22 RAPx PBID : 16700210877A0254370E15BF0704907B6C807BA5 RAPx MODE : 00 RAPx HASH : BAF3A9C3DBFA8454937DB77F2B8852B1 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT FLID0 : 0001003F-00008A21, Amd 72NS512PD CMT FLCNT : 00000000000000000000000000000000000000 CMT MCID0 : FFFF0000-00000000 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 CMT KSIG0 : 3E96DE4212587183E5E16BB2C79692A53C19875D CMT VPP : Internal DUAL LINE : True CMT ALG Boot OK INFO_2ND : APE Chip Absent INFO_ALG : APE Chip Absent Rebooting Mobile MCU SW : V 10.10 23-03-09 RM-303 (c) Nokia PPM SW : V 10.10 23-03-09 RM-303 (c) Nokia X Prd.Code: 0564418 Bpr.Code: 0544850 Prod.Sn : DUA994192 HW Vers : 1004 EM VILMA: 15 EM BETTY: 22 RFIC Ver: 064c0609 DSP Vers: ICPR71_09w03 LCD Type: SEIKO IMEI : 352072-02-651226-2 SL Serv : SIMLOCK SERVER SL Conf : 244-07-00000000000 SL Prof : 0000000000000000 SL Count: 00 00 BLK1= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK2= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK3= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK4= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK5= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK6= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN BLK7= L1: OPEN L2: OPEN L3: OPEN L4: OPEN L5: OPEN Provider: Nokia Test;Finland problem solved ... hopefully help |
02-23-2010, 15:43 | #4 (permalink) |
Insane Poster Join Date: Mar 2008
Member: 730358 Status: Offline Thanks Meter: 5 | 5130 water damage plzsolu. 1ST BOOT : C0,07 [Rm-495] [2.0.9.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 0A20020440EF7D5635DE1FF7EACDF28869B609C9 RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT UNKID : 32 02FFFFFFFFC800 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT ALG Boot CERT MISM Rebooting Mobile |
02-23-2010, 17:16 | #5 (permalink) | |
Junior Member Join Date: Jul 2008
Member: 826061 Status: Offline Thanks Meter: 0 | Quote:
1ST BOOT : C0,07 [Rm-495] [2.0.9.0] RAPx ID : 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 RAPx PBID : 0A20020440EF7D5635DE1FF7EACDF28869B609C9 RAPx MODE : 00 RAPx HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 RAPx ROID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT UNKID : 32 02FFFFFFFFC800 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT ALG Boot CERT MISM Rebooting Mobile Report Post Reply With Quote | |
02-23-2010, 17:30 | #6 (permalink) |
10-15-2010, 19:10 | #11 (permalink) |
Crazy Poster Join Date: Jun 2010 Location: India
Member: 1335527 Status: Offline Thanks Meter: 5 | nokia 5130 water damage.on hone ke bad nokia aata hai fir whit light ho kar band hojata hai.maine lcd canecter badal diya fir bhai wahi candisan hai.ples help me? |
10-10-2011, 07:05 | #13 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1154225 Status: Offline Thanks Meter: 1 | 1ST BOOT : C0,07 [Rm-495] [2.2.0.2] CMT ASICID: 000000010000022600010006030C192101033000 EM 1 ID : 00000296 EM 2 ID : 00000B22 CMT PUBID : 12B0000869448E5650E1AF99284B7D9BAB17E024 CMT MODE : 00 CMT HASH : 9DDBFCFE6E73CED7D8C6268C8EB85723 CMT ROMID : 273F6D55DFAAF68F CMT 1ST Boot OK CMT 2ND Bt: RAP3Gv3_2nd.fg, Ver: 9.11.1 CMT UNKID : 32 02FFFFFFFFC800 CMT 2ND Boot OK CMT ALGO : RAP3Gv3_algo.fg, Ver: 9.17.0 00000000: 02 00 00 00 00 D1 72 ......r ERR: CMT ALG Boot CERT MISM Rebooting Mobile plz help argent.......... |
N70 Water damage HELP ME | palav | Nokia Hardware & Hardware Repair | 7 | 06-30-2010 09:53 |
2626 water damage help me | palav | Nokia Hardware & Hardware Repair | 3 | 03-28-2010 17:08 |
5130 concat servise help me plz | naveedbutt | Universalbox | 1 | 12-21-2009 13:13 |
k610i short by water damaged,help me | shivam4you | Sony Ericsson Hardware Repair | 0 | 03-07-2009 07:39 |
C-975 Signal Problem Water Damage.....?????help Me..... | MUNEEB_AKHTAR_RAZA | Motorola Hardware Repair | 1 | 10-29-2007 09:57 |
