5130_2700_7210 flashing ok but shows only nokia on screen 100%good solution 5130_2700_7210 flashing ok but shows only nokia and goes white just remove camera problem solved 100% |
nokia 2700c after flash hang nokia log 100% after flash ufs box apply sx4 save cmt and joy |
Are u tested ? How many ? |
but ur 100% failer becoz after remove cam 85%phones not alive this complaint did u see this link http://forum.gsmhosting.com/vbb/f299...n-off-1111927/ |
5130 after flash hang on nokia 100% solution Quote:
no i have done this many phones but no result just flsh with new version if not solved change the avilma ic tested by me many times |
if rpl damaged then Nokia logo for long time also persist (APE damaged in smart phones) ............................. mostly its a hardware fault in 2700 - 5130 |
pls were is betty ic located on the bord pls imge needed |
near battery terminal,,,if u have mind |
😊Back up device rpl and full pm. Replace flash chip 😊Then flash any version Afther flash write rpl and pm file 😊1000% ok frind try this Sent from my iPhone using ******** - now Free |
