02-18-2010, 18:29 | #1 (permalink) |
No Life Poster Join Date: Jul 2005 Location: Mobile solution at Pak_Lahore Age: 46
Member: 158032 Status: Offline Thanks Meter: 331 | 6030b hang when make a call or open messages Here is the jaf logs Powering on the phone... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Reading... MCU SW version: V 5.25 21-08-06 RM-225 (c) Nokia. HW version: 0511 PCI version: UEM version: 1328 UPP version: 8241 LCD version: ELBE PPM version: V 5.25 21-08-06 RM225 (c) Nokia. mcr Production serial number: MYE518550 Product code: 0527408 Module code: 0202572 Basic production code: 0519975 Flash code: Order number: Product specific data: Long production SN: ATO: Default SN type: IMEI plain: 011239002155282 IMEI spare to net: 0A 11 32 09 20 51 25 08 IMEI SV to net: 03 11 32 09 20 51 25 18 F6 Master Code: 7663165153 Phone type: RM-225, Software version: 5.25, Language Pack: mcr User code: 12345 Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Searching for saved ini... Checking for file C:\Program Files\ODEON\JAF\JAF_RM-225.ini Saved INI not found, loading INI list... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ Searching for default location of ini... Checking path: \Products\\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\\ No ini files found... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Done! |
Nokia 5530 power off when make a call or recieve | arafay | Nokia Hardware & Hardware Repair | 20 | 03-22-2014 07:43 |
..::5130 set off when make a call or recieve a call::.. | HUM | Nokia Hardware & Hardware Repair | 71 | 11-27-2011 09:48 |
iphone 1.12 hang when make call and don't answer after unlock | patric | iPhone 2 / iPhone 3G / iPhone 3GS | 11 | 02-21-2008 12:58 |
After flashing 3200 it cannot make any call or answer any call. | smartfone | Griffin | 5 | 11-24-2005 02:45 |
