Old 10-05-2009, 03:05   #1 (permalink)
anajnisha's Avatar
Member: 1033632
Thanks Meter: 62
5130c2 power button is not wrking
I have 5130c2 nokia . it was water dameged. when i conntet charger charging is properly sow. but power key is not work. cause powey key treck is break . please help me with picture. its urgent pllese help me .
The Following 2 Users Say Thank You to anajnisha For This Useful Post:
Old 10-05-2009, 03:10   #2 (permalink)
Haicha's Avatar
Member: 330579
Thanks Meter: 67,512
Friend!Phones damage with water is better you go to any good tecnician.
Water don't break any key.f you have anything break you need new.
Regards
Haicha
Old 10-05-2009, 03:15   #3 (permalink)
anajnisha's Avatar
Member: 1033632
Thanks Meter: 62
brother its charing ok.but not power on. any solution. please help
Old 10-05-2009, 03:24   #4 (permalink)
Haicha's Avatar
Member: 330579
Hello! I think is not Power key Problem, but Hardware Problem.
You can open phone and try put this ON.Is very easy.Open and
connect battery and press switch power in system board.
Regards
Haicha
Old 10-05-2009, 03:27   #5 (permalink)
octavyus's Avatar
Member: 242469
Thanks Meter: 503
Exclamation
the phone work ????
you can try make one bridge and test if your phone power ON
if your phone not power with bridge is imposible detect ways of ON/OFF
B.R
Old 10-05-2009, 03:31   #6 (permalink)
Haicha's Avatar
Member: 330579
Hello! Phone Problem is Hardware.Not any problem in Power.
Test all solutions, but is not any key break.
regards
haicha
Old 10-05-2009, 03:34   #7 (permalink)
anajnisha's Avatar
Member: 1033632
Thanks Meter: 62
I press the on/off key but not power ON . but when i connet charger in charging jack charging show proper. TRY TO UNDERSTAND and PLEASE HELP ME BROTHER.
Old 10-05-2009, 03:45   #8 (permalink)
Haicha's Avatar
Member: 330579
Friend! Phone Charge OK? I understand very good.But this is anything.
Your problem is phone don't power ON.You have all here for try see if
is Power button or not.If Power Button is ok is Hardware Problem.Is not
easy help in this case.Phones Damage with water is big problem.First open
phone and try remove water.
Regards
Haicha
The Following User Says Thank You to Haicha For This Useful Post:
Old 10-05-2009, 05:00   #9 (permalink)
Member: 823633
Thanks Meter: 1,705
bro try
http://img40.imageshack.us/img40/357...playsoluti.gif
The Following 2 Users Say Thank You to vaghubha_sodha For This Useful Post:
Old 03-25-2010, 10:38   #10 (permalink)
Member: 458017
Thanks Meter: 7
Wink
pls download Scematic From www.Shrak-mobile.com/eng
and trace the power on track
The Following User Says Thank You to moideenkutty For This Useful Post:
Old 03-25-2010, 11:05   #11 (permalink)
mahbubalfa's Avatar
Member: 1003058
Sonork: 100.1589274/mahbubalfa
Thanks Meter: 26,433
Bro.try this solution.
http://forum.gsmhosting.com/vbb/f148...s-asad-900071/
The Following User Says Thank You to mahbubalfa For This Useful Post:
Old 02-28-2011, 13:07   #12 (permalink)
Member: 1493866
Sonork: yawar
Thanks Meter: 2
hiiii
Originally Posted by ashad420 View Post
thinks four good solution but nokia 6300 key ped ic is use 5130c
Old 02-28-2011, 13:09   #13 (permalink)
abidottupara35's Avatar
Member: 1178222
Sonork: 100.1602620
Thanks Meter: 467
change keypad ic i hope ur problem solved
Old 09-29-2011, 10:10   #14 (permalink)
Member: 1595414
5130 death (or ) power key solution please help
Old 07-28-2012, 15:46   #15 (permalink)
nainosoft's Avatar
Member: 1713692
Sonork: 1637132, QQ-2486154669
Thanks Meter: 187
Thumbs up mobile phone schematics link
thanks brother, this link is very usefull
rd2030 on only when power button is pressed gsmsikar Various CDMA/TDMA Cell Phones 2 09-03-2009 20:45
Samung U700b Power Button does not work after flashing paul jones jr QUALCOMM Models (3G) 4 05-23-2009 00:53
W600 power button does not work.... luisfer99 Sony Ericsson Hardware Repair 0 04-25-2007 04:17
3220 no power on, but the power button is good real1ed Nokia Hardware & Hardware Repair 8 03-20-2006 18:29
c60 not answer when power button is pressed ziko E-Gold Based Phones 2 09-22-2005 16:02
Page generated in 0.32713 seconds with 9 queries
